Creating Computrainer course
I am attempting to use the Course Creator from Training Peaks, http://cc2.bradculberson.com/course_creator/cc2, for the first time.
It appears that I am not getting any grade info when I save it.
As in:
UNITS = ENGLISH
DESCRIPTION = IMCDA
FILE NAME = course.crs
;DISTANCE GRADE WIND
; Created by Course Creator 2.0
; http://cc2.bradculberson.com
; Created by Brad Culberson
0.043 0.0 0
0.116 0.0 0
0.058 0.0 0
0.463 0.0 0
0.058 0.0 0
0.220 0.0 0
0.110 0.0 0
Has anyone used this successfully that can point out the error of my ways?
The first column is the length of the leg, and the second is the grade. Since your second column is all zeros, your course is flat. But I have not used the Training Peaks course creator.
Make sure that after you layout your course, you click “Get Elevation Data”, hit save, then do the export.
-gear
Gear is the man.
I didn’t realize getting the elevation data was a seperate step, even though I did it seperately, and that I needed to save afterwards.
Now I may have to ride tonight to check out the new IMCDA course.
