Crankset question for the wrenches
I picked up a crankset at one of Performance Bike’s clearance sales, an impluse buy
http://www.downtube.com/FSA_Carbon_Pro_Team_Issue_Crankset_2005_Team_Issue.html
I paid $80. A screaming deal, I think…
I’m planning on putting them on my new R3 frame that I just ordered. They are ISIS drive, not MegaExo. Any recommendations on a good bottom bracket? It seems ISIS bb’s are kinda hard to find. Also, it needs to work with Record 10 which is what I’m planning on putting on the bike.
Also if anyone has thoughts on ISIS vs. MegaExo and why I should or shouldn’t care about the difference.
FSA Platinum Pro will work just fine.
I have that set-up with Chorus 10.
I think there’s a reason that the whole industry is moving away from the ISIS standard…
THat said, FSA makes an ISIS Bb still.
Or you could go with Zipp. It’s supposed to be Ok…
http://www.wisecyclebuys.com/index.asp?PageAction=VIEWPROD&ProdID=431
well, if its an indication of how little I know, I didn’t really notice they were ISIS when I bought the cranks. I just saw the price and jumped on them…
Oops.
“I think there’s a reason that the whole industry is moving away from the ISIS standard…”
Is this true, or just your opinion? Clearly you have Shimano and Campy doing their own thing, but what about the rest? Seems like the ISIS standard isn’t a bad one at all.
There really isn’t much of a problem with ISIS in general, just a few poorly designed ISIS BBs around that have lead to some bad reviews.
Buy the token ti version fro Pro Cycling Discount on Ebay. It’s a very, very nice piece of hardware and it’s going to leave you stranded.
Chris
Not an expert, but I remember the talk being problems with engagement between the spindle and the cranks, and the splines being more easily damaged, but I could be wrong. I have a mix of MegaExo, Octalink, and square-taper. No problems with any of them. Who knows, if I had ISIS, I might not have any problems with that either.
ISIS was developed by/for companies that didn’t want to pay Shimano to use their Octalink system. There’s nothing wrong with ISIS. It solves the same “problem” that Octalink did; it’s better than square taper. (I say “problem” because some people insist that square taper really wasn’t a problem and that Octalink was another case of Shimano and the “planned obsolescence” conspiracy theory. Both really are better than square taper, by the way.) But, the new external bearing bottom brackets are better than any of the previous iterations - square, Octa, ISIS. So, there’s nothing wrong with ISIS, it’s just been surpassed by a newer and better method.
isis or octalink is better then sq tapper ???
i don’t see an advantage the bearings are the same size
i do like the new out board bearing systems
dirt just my 2 cents
The advantage doesn’t have anything to do with bearing size. The advantage of ISIS or Octalink is that the interface between crank arm and b.b. is much more precise / secure. An ISIS or Octalink crank arm will never “wallow out”, which square taper crank arms have a tendancy to do over time.
