i have a self extracting crank that is stuck. i have been searching the web, and most posts seem to be more severe than mine, mostly stripped bolts etc. i am trying to get my crank off with a standard allen wrench before taking to the LBS and paying. any tips? i want to be careful because nothing is damaged as of yet.
I would give up on the self-extractor and pick up the Park crank extractor tool, so you can save the threads. There’s a couple models, depending which crankset/bb you have. They’re only about $13. http://parktool.com/products/detail.asp?cat=26&item=CCP-4
Position the allen and the crankarm closely together too. You can generate quite a bit of force when they are at a more acute angle than if they were farther apart.
If you haven’t loosened/removed the crank bolt or the dust cap, the odds that you’ve done any damage to the threads is extremely low. If the threads are damaged and you haven’t removed any of the bolts before then there damage was done before you ever tried to remove the cranks.
First I would lubricate everything about, from what I remember the self extracting bolt has a flange on it the pushes against the piece that threads into the crank arm. If this is dry, it can be very hard to remove. Then, what I use is an allen socket and a socket wrench, much more leverage.
