Crank Length is directly related to power
Great question. The short answer: very few things in the bicycle industry are done based on logic, science, or efficiency. Sadly, this is a sport hidebound by tradition, many archaic rules, what makes the most money for manufacturers, and other misc. goofiness.
However, if you want your questions answered (and get even more to think about), go here and read the associated linked pages–not necessarily the last word, but great food for thought:
http://www.nettally.com/palmk/crankset.html
“Why did you have to include the first paragraph? To be a dick? The second paragraph would have suited just fine.”
When someone makes a post insinuating that triathletes “just don’t get it” he is sort of asking for a confrontation. It happens all the time on internet forums. I once got into a tiff on another forum over fluid dynamics with a guy who kept claiming he knew what he was talking about because he had a PhD. Turns out that the PhD was in environmental engineering.
Back to the original point, there have been many tests conducted with both trained and untrained cyclist and crank length has never been shown to make a statistically significant difference. Anecdotally, I will add that all of my PR’s have been set since I switched from 175 mm cranks to 165 mm cranks. I can ride with my handlebars 2 cm lower with 1 cm shorter cranks and that is what I attribute my speed gains to.
Hey John, ignoring your anecdotal results, if you actaully talk to true experts in the field (professors in human biomechanics) and take a detailed look at the literature out there, it is impossible to conclude much on the ideal cycling crank length for human beings, but not necessarily because no such relationship exists.
For one, good, scientific, comprehensive, controlled, peer-reviewed studies with decent sample sizes have simply not been done to fully address this question. Most studies that have been done either do not address ideal crank length and/or do not address whether crank length should/should not be proportional to leg segment length. Other studies that have tried to in some way address this are very small, are badly flawed, or have conflicting results.
Perhaps the main reason is that good studies have not been done to address this question is because such studies would be quite expensive, and nobdody is thrilled to pony up the money to discover that 90% of folks are riding less than optimal crank lengths for their body and/or for their cycling sport. And then to find out that the optimal cranks are simply not manufactured for 50% of these folks or that optimal cranks would have mechanical conflicts on current bicycle frames.
BigClyde, lets talk motors if that is your gig, and then we’ll see if motors, which are really just air pumps, and people, which are also air pumps, are analogous.
Standard 350 Cubic Inch Chevy 4.000" bore / 3.480" stroke
Standard 400 Cubic Inch Chevy 4.125" bore / 3.750" stroke
A really common stroker motor is the 350 block bored .030" over with the 400 crank .01" longer to fit the 350 main bearing crank journals, this leads to a 383.
Down low, with identical cam and intake/exhaust valves, the 383 is going to make more torque than the 350, right? However, the heads are the limiter as far as horsepower is concerned. The difference being that the 350 will make it’s peak horsepower at a higher RPM than the 383. Hypothetically, the 350 will make 350 horsepower at 6,000 RPM, while the 383 will make 350 horsepower at 5483 RPM (350 x 6000 / 383 = 5483). So, the question I think that needs to be asked is “How often do I have to shift gears/How quickly do I need the motor to wind up?” If you’ll be shifting gears a LOT, then the 350 ci motor is probably the better choice in my opinion. If not much shifting is going on I’ll take the 383.
Can this be applied to the human body/bike combo? Maybe. If we are out on a course where considerable amounts of gear shifting is necessary then maybe it would be better to run a slightly shorter crank so you can reach your peak torque RPM quickly after shifting. I use “peak torque” because it is generally accepted that this is where a motor is most efficient, and peak horsepower is not analogous to humans because we don’t have an unlimited supply of gas. On the other hand, if you are on a course that is extremely flat, then the longer crank arms might be better suited because they will allow you to make peak torque at a slightly lower RPM, which takes less concentration.
Either way, you can’t stroke a small block 350 circle-track-motor(Like me) and turn it into a bib block mountain-motor 632 (Like Lance). I do think this is something that applies to the Bjorn Anderson arguments. He is like the mountain motor that makes peak torque at a low RPM.
Greg, you are correct that a large comprehensive study has not been done, but none of the smaller tests have returned any data that shows any inkling of a correlation.
Perhaps if cycling had the revenue streams of NASCAR or the PGA, we would see more tests done addressing the issue. Until then, I think we have to stick with the results we have so far.
Holly hell batman! I want you to work on my car!!!
I think you hit one of the nails on the head. I ride with 180mm and I love them, however, there is a noticeable cost too. At the top of the stroke the hip angle is much tighter and as a result I need to rely on working my gluts more to initiate the downward phase. Add to this the fact that the angle is already shortened from being in an aero position on tribars and the longer crank is a noticeable difference. That said, I like the fact that I get more torque.
On another note…I still have a set of Shimano biopace cranks that I am seriously thinking of dusting off. The logic behind them seems incredibly sound to me. I asked Steve Larsen for his opinion on them and he mentioned that although they may be better for cycling performance, many cyclists suffer knee injuries with them. I never got an injury with them so I am thinking of giving them another go.
“At the top of the stroke the hip angle is much tighter”
I ride higher on my tri bike than I’d like to because of a back injury that has left me with very tight hip flexors and virtually no flexibility below T-12. I’d love to ride longer cranks, because I don’t spin real well and I think it would give me more power, but when Christopher Kautz fit me on my tri bike, he tested that option and said I had a lot of work to do on hip flexion just to get my saddle down to where it ought to be.
“I think you hit one of the nails on the head. I ride with 180mm and I love them, however, there is a noticeable cost too. At the top of the stroke the hip angle is much tighter and as a result I need to rely on working my gluts more to initiate the downward phase. Add to this the fact that the angle is already shortened from being in an aero position on tribars and the longer crank is a noticeable difference. That said, I like the fact that I get more torque”
Could that mean that working with Powercranks would allow someone to ride with longer regular cranks for racing for example, thus get more torque and ultimately go faster ?
I cannot answer that because I have never used or read up on the benefits of powercranks.
Ah, the man with the ever-changing screen name!
You may be able to think of several, but none of the references you directed to me earlier meet any of the criteria of actually addressing this question. Also, folks that actually know and work in this field disagree with you. So, in your opinion, it appears that anything is possible. But other than your vague reply that you do not back up with any real examples (with actual study details and references), we are still nowhere…
