Slowman and few others here have recommended shorter crank length with smaller gears, to allow a more open hip angle etc.
If I read well, Rappstar used 172.5mm cranks with 53 big chainring and may go to 170mm.
Who has tried shorter cranks? Feedback? How did you modify gearing?
Given that Jordan is hmm…one or 2 inches taller than me, I’m thinking I would need to use something like 165 or 167.5mm and get rid of the 55T for something smaller…
very odd thing to say for someone of your academic background. because if you accept that any guideline for crank length should be proportional (and logic says that it should be), than take jordan’s inseam and 170mm, and then take your inseam and an unknown, and then set up equivalent fractions. my guess is that you will come up with a number far smaller than 165mm.
Well, I am 6’2" and currently experimenting with 165 cranks (as short as my cranks will go and my big chain ring is a 58). Before this I was experimenting with 182.5. I find the shorter cranks demonstrably “easier” in the aero position and I think my speed is actually up some. It took a day or two to get used to the little bit “harder” pushing but I have no problem now. I see no reason not to try the shorter cranks and I see no reason to go to a smaller big ring.
how does using smaller gears open up your hip angle?
Very funny. How many manufacturers make cranks of length smaller than 165mm? Or do you recommend BMX cranks?
Well, soon all of our cranks are going to go as short as 155mm and our long adjustable cranks have always gone as short as 85 mm.
actually i was being serious. for jordan, 170mm may be slightly small, but for you (if you use logic and proportionality, and few people do around the issue of crank length), realistically, you’re going to have to go a lot smaller, very likely smaller than 165mm. how much smaller? i don’t know exactly how long your legs are, but the bikes you have posted are small. set up an equation as i suggested and at least you will have a ballpark target. you don’t have to go with bmx cranks. there are some custom crank companies that will make cranks whatever length you want.
that said, while you may want to experiment, i personally am not so sure “short cranks for triathlon” is really the way to go. while i do think you gain something with short cranks, you also lose something with short cranks. there is no free lunch …
