Experimenting with crank length and want to go back to 170s… Anyone selling anything or willing to trade for some 175s?
I have a 170mm that is brand new. $375 shipped. see here:
http://i1164.photobucket.com/albums/q578/triguy44/082_zpsf40b29a2.jpg
http://i1164.photobucket.com/albums/q578/triguy44/083_zps45e6d629.jpg
http://i1164.photobucket.com/albums/q578/triguy44/084_zps1ffa273a.jpg
http://i1164.photobucket.com/albums/q578/triguy44/085_zpsdc71dd10.jpg
http://i1164.photobucket.com/albums/q578/triguy44/086_zpsca3d249b.jpg
http://i1164.photobucket.com/albums/q578/triguy44/087_zps6d652399.jpghttp://i1164.photobucket.com/albums/q578/triguy44/088_zps3d1bc43b.jpg
Sorry, looks nice but I need to road version. I’ll need to be able to remove the spider to attach my power2max power meter. Thanks though.
gotcha… sorry if I missed that in the post. Good luck.
I have a set for $150. 170mm. Just got a power2max and got the whole thing with rotor 3D included so the set (without chainrings) is
available.
3D or 3D+?
3D. Didn’t see you wanted 3D+.
The crank that mybikeshop posted would work for you. That spider is removable, just like on the road or all other versions. Would require the same rotor3d plus tool. The lockring just looks different but the pins on the tool fit into those holes. If you look closely you can see it is actually two pieces. I’ve done the swap for a few riders on the same crank.
Oh I thought it would require a different tool. Thanks for the heads up
The notches or pins on mine are round and semi-round for my rotor3d+ tools and it worked for the ones I have done. As long as you have rounded or semi rounded notches on the tool you should be good to go. Spindle length and width, everything else is all the same, the only variance for that crank to a regular/road 3d+ is the spider.
found
this still available?
thanks
