Crank bolt keeps coming loose
I recently took apart and reassembled my bike. Ever since my left crank bolt keeps coming loose. I only get about 50 miles and I need to tighten it up again. I can always tell when it is getting loose because my crank starts to creak when I climb out of the saddle.
I did grease up the bolt before tightening it. Perhaps this was a mistake, but that’s what Zinn tells me to do.
I did notice that when I took of the crank that the shop that assembled it used some sort of coating that was not grease. It was blue, I think, almost like a paint of some sort. Is this Lock Tite and if so should I use it?
And no, before anybody asks, I don’t have a torque wrench. I know I should get one, but they are a bit pricey.
Thanks,
Victor
Blue locktite should do the trick. especially if it happens to be a carbon crank with no pinch bolts.
I had the same issue (although it wasn’t loosening every 50 miles…usually every 500k it started loosening just a little) and used the blue locktite which solved the problem.
does this happen to be an FSA crank (SL-K)? They are famous for this …
No, Campy Chorus 10 Speed. I’ll try the blue lock tite.
I experienced the same problem a few weeks ago. In fact, the bolt loosened so much, the crank came completely off the spindle and was dangling from my cleat. Definitely one of those WTF moments. :slight_smile:
I had a multitool with me, but the short length of the hex key gave me very, very little leverage to tighten the bolt. The crank would loosen every few miles.
The solution turned out to be very easy. All I had to do was take a hex key and insert the long end into a long piece of small-diameter pipe to give me plenty of leverage to tighten it much more securely. I rode the bike on a 70-mile ride last week and the cranks stayed tight the whole way.
I didn’t use Loctite, nor do I own a torque wrench (but now I’m planning to get one).
Jim
Weird. I presume square taper. In that case some Locktite 242 (blue) is all you need…and make sure the washer is in there as well.
Yes, square taper and I the washer is in there. I probably over greased the threads, so this weekend I’ll clean off all the grease and apply the blue locktite.
Thanks all,
Victor
Yes, loctite blue and CRANK down to torque spec (which is high)
I’m not familiar with your specific crank, but those square tapers are generally torqued to your maximum arm strength! Crank that baby on there.
Although blue locktite might be a more elegant solution.
I had a similar problem on my '07 Specialized. The company was sending out assembly bolts that were too short for the threaded depth, so after the first removal it would never seat correctly again. Make sure that the threaded length is correct, then use an appropriate amount of loctite to secure it.
