Craft Kona Tri Top and proCOOL Long Sleeve
Other than the spot on the back of the Kona top to hold sponges is there any other difference in these two tops? Thanks!
I am curious about this also. They are both proCool fabric and I believe I saw somewhere the only difference is the sponge/ice pockets. But the description on the TriSports.com website is much longer for the Kona top. It says proCool fabric but it also mentions the following benefits that are not mentioned on the description for the “regular” top:
SPF 50 Ice pockets on the back for additional temperature control Hexa-continuous filament fabric 6 channels that pull perspiration away from the body
SPF 50 when dry or wet? if wet it would be great most white fabrics drop to an spf of 5 or so when wet
Does the SPF wear off in the washing machine of after prolonged use?
Basically when wet, the sun better penetrates the clothing. http://www.medicalnewstoday.com/articles/23774.php
