Could this be a stress fracture?
Now I know there’s no way to tell for sure,unless I get and x-ray/MRI done,but I thought I’d throw my symptoms out there.
About 2 weeks ago I was doing a treadmill run,and started to feel a little discomfort on the inside of my tibia,just above the ankle.Its more of a dull pain(doesnt hurt much at all really),when I put any weight on it.
Like I said,it doesnt hurt much when I walk/run,but its sensitive to the touch.
I can swim and bike without any problem,but havent been running at all.
I know there are some of you out there who have had stress fractures,and I was just wondering,if these were some of the symptoms?
Thanks
Obviously you should really get a doctors opinion and yadda yadda yadda. But for what its worth when I had my stress fractures - both shins severely fractured they hurt non-stop all the time. I was running XC for a Div I school and had a very bad trainer who just kept giving me stuff for the pain and telling me to ice. Just as an example to let you know what the pain was like I would take between 250-500 mg of codeine before bed so that I could sleep through the night without being woken up from the pain. And around 1000-1500 mg of ibuprofen before every run and randomly throughout the day. I did this for about 4 months and yeah I know I was dumb and my shins are still weak from this but im telling you just so you have an idea of what the pain was like for me. What you are describing to me really sounds like shin splits. dull achy not real bad. this is what I would do.
  1. Ice after every run! We use to take Styrofoam solo cups and fill them with water and freeze them. you can peel the styrofoam down and then you can ice your shins and apply some pressure at the same time. very effective.
  2. make sure your legs are warmed up before you start running hard.
  3. keep off of the pavement as much as possible.
  4. go to a good running specific store with a pair of your old shoes. Have them analyze the shoes to see what your pronation is. Then ask them to suggest an orthodic or off the shelf insole. Most good running stores can custom make something for your feet. Once your feet are aligned properly and supported better you should not have many shin problems. Also this can help correct any knee, hip, or back pain you experience from running.
Hope this helps.
If you could be a little more specific as to what you mean by “inside of the fibula”
Runners will typically develop a stress fx of the distal tibia (weight bearing) as the fibular is a non weight-bearing bone, but I do see some.
I’ve had recurring stress fractures in my femurs…mine would wake me up in the middle of the night with throbbing pain. At first I could run without any pain, but eventually even the kick during swimming hurt. Get the MRI (x-rays often appear normal for 3-4 weeks after onset…although they will probably start with one anyway). I’ve learned to catch my stress fractures very early on, and just take a week or so off running. But if you keep going, they will get worse.
Do not take any Naproxen or advil as they can interfere with bone healing. Take tylenol if you need something.
Good luck, I know how frustrating it can be…Get in and see a GOOD sports ortho doc, and maybe a physical therapist. If it is a stress fracture, it sounds like you have caught it early.
Could be. But w/o more info it’s tough to make the call. My understanding of one of the ways a stress fracture occurs is that the muscles become so fatigued that their shock absorption capabilities are diminished; then, over time, b/c the muscles are tight and pulling on the bone, and the bone is absorbing more shock then normal, a fracture occurs.
Is the pain localized, or over a broad area? Can you tell if is it muscular? Have you tried self massage?
Skip the MRI, too - get a bone scan - that will be the most sensitive.
A lot of insurance companies first require an x-ray, then an MRI and then a bone scan. Nice.
That would suck - I’ve had traditional Blue Cross and HAP HMO for both the times I had suspected stress fractures - after the x-ray in the doc’s office which was obviously negative, both insurance companies let me go right to the bone scan.
Could be based on what you describe about the weight bearing. I fractured my hip and tore my hamstring and would describe running at that point as “uncomfortable” meanwhile I was biking and swimming at a fairly high volume…so given different people’s tolerance for pain and the added variable of the current severity of the fracture, it can be “annoying” to very painful.
My understanding is that a new fracture that isn’t severe might not be picked up on an x-ray at all. Not sure about the claim of a bone scan being more accurate either - - I’ve had bone scans for my arthritis and is is also a nice dose of radiation (and you will be a little radioactive afterwards so you can sing that song “I’m radioactive!” or whatever), so personally I would stay away from a bone scan if possible.
See and orthopod who specializes in sports med. They may want you to have an MRI. In the mean time NO WEIGHT BEARING ACTIVITY - - because if it is a fracture, you will make it worse.
rroof,
My mistake. I meant to say tibia.
<<Is the pain localized, or over a broad area? Can you tell if is it muscular? Have you tried self massage? >>
The pain is in one small area,and as I said its sensitive to the touch.Very hard to tell if its muscular.
I’ve tried massaging the area around where the pain occurs,but not directly on it.
I had a stress fracture once and it had pretty much those identical symptoms. It was also in the area just around my ankle. It was a dull throb if I tried to run (enough of a warning sign that I didn’t run), and pretty intense pain if I touched the spot. I was able to bike without problem and swimming was only an issue if I pushed hard off the wall.
Don’t run until you get it diagnosed. The doctor told me that was critical and why I healed pretty quick.
Ah tibia and focal - yes, need to suspect a stress fx until proven otherwise.
As to the MRI vs. technetium bone scan debate - doesn’t really matter. A Bone scan is more sensitive, but not very specific. An MRI is a little less sensitive, but more specific. A CT scan is very specific (shows the best bone detail), but misses the marrow edema often seen in a very early stress fracture or “stress reaction”
Based on your early catch/description - you likely have a stress reaction (or medial tibial stress syndrome - new buzzword), but go get some confirmation and stop running now. Swimming is fine. Spinning on the bike only if it doesn’t hurt (no standing/mashing).
Good luck!
