Corima seatpost- anything else in 25.0?
My Guru takes a 25.0 post and the Look it came with is crushed from overtightening (I guess-I bought it used) and slips. Anyone like or dislike the Corima post or have any favorites in a 25.0. I have found that there are not that many choices- Look, USE, American Classic. Anyone have anything decent they want to get rid of?
I love the Corima post. I have used one for many years on my old Trek OCLV (Linda). I love it on my Fox (Samantha), as well.
Make sure that you tighten down the orb (the big ball that holds the seat rails) well so that it bites into the carbon. Also, remember that it only takes the narrow railed saddles.
Selcof makes a 25. seat post which is also bi-positioning. It works well when you are looking for a more forward position.
maybe Use?
25mm seat post and my LOOK bike:
Corima, I’m having problems with mine, in my LOOK bike front to rear movement even after very tight clamp. Any solutions, I’m thinking 1-2mm of epoxy on edges and file to fit?
Selcof, found not enough bolt for saddle tilt down 1-2degrees in forward position, ie from 72degrees to 76deg
any help???
Do you have Thompsons WWW.??? Thanks
It’s: http://www.lhthomson.com/
