I’m looking to buy my first full tri suit for IMAZ. I like tha lack of a waist band, as those often cause me back pain. (That’s why I used my DSS TriBibs for my century/brick, last weekend. I’m looking for one that doesn’t chafe the ‘taint’ and is cool on the run and preferably comes in a light color.
Maybe obvious, but DeSoto is the way to go. Only have four (silver, red, blue and yellow) hanging in my gear closet. Good fit, durable, and the service and quality that Emilio is known for.
speedy, what is the inseam length for the power tri shorts? Is it the same as previous years? I have a set of power tri shorts I love but I would prefer them with the four pockets and I may be the only one but I’d like them about 2 or 3 inches longer. I’m wearing a size L.
check out the 2XU comp tri suit http://2xu.com/mt1001d.html
it is amazingly comfortable and well made. all true flat lock stitching that moves with the body, so no chafing. also using prime Lycra, and not cheap elastanes that many people use, makes the material hold better and last longer. the mesh sides add ventilation, and the denim color has a white back as well, so perfect for arizona. of course 3 pockets on the back.
they will be out in shops by the end of next week.
best of luck at arizona, stop by the Inside Out booth and say hi, i will be there working all week.
chris www.2XU.com
hey chris, you from 2XU? if so just wanted to let you know after using orca for a while i picked up a pair of 2XU tri comp shorts (out of necessity, my options were limited and i was in a hurry). damn nice shorts man, they feel sweet! one thing though, even in a XS the waistband feels like it should be a bit tighter, the back fills with water when i push off the wall, had to re-tie them real tight, which was a pain to do in the pool. otherwise, very impressive…
hey show pony, thanks for the feedback, and great to hear you like the shorts!
the waist band is a fine line, but very useful info that i will pass onto product development
let us know how they hold up to the chlorine compared to your Orca shorts. i think you will be impressed.
all the best for your tri season
Chris www.2XU.com
