Considering swapping to SRM
I’m looking for a little advice here:
I have two bikes and two sets of wheels. I’m addicted to using power to train; at this point, I can’t see giving that up.
I have one set of 808 tubulars and one set of reynolds mv32c (32mm depth clinchers) both with powertap 2.4+. I use the garmin 310 to collect/record data.
I’d like to have a little more ability to change up wheelsets based on weather/wind/etc, and I don’t want to have to keep buying/finding wheelsets with powertaps in them (and then doing the ANT+ update, etc). One solution is to buy 2 SRM units, sell the powertap wheelsets, and then buy whatever I want. Pretty big pain to do that, not to mention taking a cash hit on the wheelsets.
For those of you out there that have made a similar switch, would you do it again?
Any issues with SRM vs. Powertap that I might not be considering?
I have a Specialized Tarmac sl2 pro, and a kuota kalibur. I’m not likely to change either of those out in the next 3 years or so.
Thanks in advance!
Keith
You have a great set-up. I think you may be looking for more “tweaking” of your wheelsets than is necessary based on wind. The only addition I might make would be a 404 front. With that, you are set. The only thing “missing” is a rear disc, but you can easily get a cover for your rear 808 for cheap.
Have you considered a Quarq?
run the 808 with a cover for races, clincher for training. What is the problem? Wind should not affect rear wheel choice
I’ve done the Powertap to SRM to Powertap back to SRM switch… My advice would be to keep what you have, as long as the 2 PM’s are reading consistently close to each other. No matter what you do, there are always compromises. Remember that while a crank-based PM may give you more wheel flexibility, it also give you less crank flexibility. While this may not sound like a big deal, what if you want to try different crank lengths, or you get a frame with a different BB standard? The Quarq is a compromise as well, since you can’t change the chainrings without sending the unit back (though I’ve heard there’s a workaround for this).
This isn’t theoretical mumbo jumbo, this is my actual experience: the inflexibility with the cranks is just as big a hassle (or more) as the inflexibility with the wheels. And realistically, with an 808, a semi-deep aluminum training wheel and a cover, you really have all of the bases covered.
