I’m looking for some advice for setting up a road bike for tri’s next year. I’ve ridden a steep setup for the past few years for tri’s (approx. 78 degrees) However, this year i’ve landed a great deal with a bike sponsor. The only catch is that it’s a road geometry bike. Very stoked about the early base miles and Crits on my new Composite frame. However, i’d like some guidance with setting it up for the tri season… Here’s what i’m thinking:
Getting a Fiz’ik Arione triathlon saddle for triathlons (leave the regular Arione on for road races)
Neutral Seat post (methinks Thomson Elite) but leaving the setback carbon post on for road races
Shorty aerobars
Plus a disc and aero front wheel… But that will be taken care of later. So basically i’m looking to be set up in approximately 75/76 degree seat angle (maybe a bit more if I ride on the nose) I’m only doing Oly tris this year (maybe a half Iron mid-season) Any suggestions?
It sounds like you are doing the right things equipment-wise. Wether or not this works for you, is really up to your ability to fit the set up and be comfortable and powerful.
You know i’m kind of excited to try out this set up… I went too steep 2 years ago. Made some adjustments this past season. But I have always felt more powerful in a slack set-up. I’m interested to see how it works out… Especially in the shorter distances.
One thing is for sure, you won’t see me sacrifice comfort for aero ever again.
Funny, I was going to ask the same question today. I bought a new road frame at the end of summer because I couldnt pass up the deal. But, I have a perfectly good road frame sitting in the corner that I want to set up as a tri/TT bike.
i think the whole matter is highly subjective. even the best (and most expensive) bike fitting is just a starting point, that has to be further adjusted, according to your special preferences. it takes years to find out, which exact postion offers the best balance between power output, aerodynamics and comfort. at least i’m still in the middle of this process (on a road bike frame btw) and i post top 5% bike splits in most races.
so as long as you feel good on the bike make only minor adjustments if at all. i don’t see a reason why you shouldn’t be able to find your position on a road bike frame (which btw for most parts can be adjusted to at least simulate a tri frame).
on the other hand - if i had the money, i’d get a p3 … who wouldn’t?
For just about everyone short of the truely world class, I think that comfort and power transmission are key. This is easily figured out using some of the basic bike fitting math and then a little fiddling to find that sweet-spot relative to the bottom bracket that is best for you. The fitting should end there, but it get’s complicated when you throw in aero bars and it can really throw people off.
If you stand at the exit to T1 at any large IM race, you will witness many truly horrific bike set-ups and positionings. Despite, ALL of the great information out there you still see people with aweful set-ups. I am not sure how they ride 112 miles like that. They should get a reward just for surviving the bike in that position!
you’re absolutely right. i think the problem ist, that many people try to imitate some tri star’s bike position, ignoring the fact, that their body composition, flexibility and on top of that - their bikes - are just not suited for a pro’s position. that’s one reason why i am a strong advocate of video analysis! if those people would know how strange they look on their bikes, it would be much easier to motivate them to work on a proper position.
