Just got and set up CompuTrainer. It crashed Windows with a message that Windows had shut down to prevent damage to the machine. First time when it was just stting at the start line, second time about an hour into a course. Anyone have this issue and find a resolution. The system I am using it on (HP Laptop)greatly exceeds all of the minimum system requirements.
I promised myself not to post to ST for five days, but I need a little help on this.
It is probably a program that runs periodically. Try shutting down everything you can. Turn off your virus scanner. Disconnect from the internet. Shutdown everything in the systray that you can. I think on all Windows flavors you can ctrl alt delete to get a list of all the processes running. Get it as clean as you can and then see if it runs. If you don’t get anymore crashes, then it is simply a process of elimination to find out which one it is.
I’ve had similar problems running the PC1 on Win98. I always use the Task Manager to shut down CEMSYS (or something like that) AND GMT EVERY time PRIOR to starting a ride.
Try looking in the even viewer at the time it crashed and see if it will give you any more detail. It may list a file or give yo a clue. You can also search the event id information.
Are you sure your machine meets the min. hardware requirments for the CT. I don’t have one so not sure how much HP they need?
Scroll through that list and uncheck everybox that you don’t think has anything to do with the major hardware in your laptop. This will shutdown all the programs that are hogging the memory and causing your conflict.
Not so great an idea if he has no idea what apps or drivers he runs on startup. Sure a lot of junk programs load into the systray at startup but so do other that he may well need and not associate with ‘hardware’.
In XP/Win 2K if you right click on my computer and go to ‘Manage’ this will open a program window with another selection in the rhs panel ‘Event viewer’. Look under Application and System for any errors, ‘red checked icon’. You have the option of clicking on the error for more info. Try this
Thanks.
It goes to a dump screen, Windows ends. I can’t do anything.
Sorry but just want to be clear that you mean the Blue Screen What does the dump say? Have you checked the event viewer? It may be that if it is BSOD that it doesn’t have time to write and event
Can you identify the applications and drivers that exist on your laptop that don’t exist on the other computer (that doesn’t crash)? My guess is that you have a software/driver conflict.
I will have to wait for it to do it again and save the dump. What a pain to get to mile 40 of a course, be doing “good watts” and time, have to stop, and lose all the info.
How would I view the event viewer? Windows has ended, do I not have to shut off the power and restart?
I was connected to a wireless network/(INternet). Perhaps I should pull out this card.
I guess we should all ask you just how comfortable you are with the computer. Are you able to try some of the things that have been suggested?
Well, I was a systems analyst and BAL programmer (that is probably such an old language that you haven’t heard of it!) before law school (24 years ago), had one of the first PC’s with a single floppy, and I have been buying and using machines since way back then, but the tech has gone way past me.
Look at tri-espana comment, last paragraph on finding event viewer but yeah you need to reboot, I would take the wirless card out since you don’t need it just in case. If it were hardware I would think it would happen as soon as you started it not minutes in to the ride.
Also when you go to MANAGE (Right click on my computer, choose Manage) look on the folder list for Device Manager and look in there for any red X or Yellow marks, this will help id any hardware conflict or missing drivers etc.
Hi!, I’m assuming you have XP. You can get to a list of every program that starts when your computer boots by clicking “Start” then “Run” type “msconfig” in the run box and click “OK” click the “startup” tab and you will see a list of cryptic supersecret Microsoft gibberish. Scroll through that list and uncheck everybox that you don’t think has anything to do with the major hardware in your laptop. This will shutdown all the programs that are hogging the memory and causing your conflict.
After you reboot you will get a message that says you have made changes to the system configuration. Uncheck the box so that it soesn’t show up everytime you reboot. I would also suggest that you get 2 programs free from download .com. Ad-aware and Spybot search and destroy. Install both and run them, they will get rid of many many spyware programs that are on your PC. You should also make sure that your virus definitions are up to date and your laptop is free form the pesky varmints.
I recently cleaned up the machine in preparation for the CT to arrive (and not wanting it to start showing porno in the middle of a ride). There is nothing checked in my “Start” file when I run msconfig. Registries have been cleaned. There are a lot of processes running that I don’t know what thery are, but no memory or CPU hogs.
Is it a ‘blue screen’ crash or a system dump, ie system dump on XP home windows tells you it “performed an illegal operation and is now shutting down” and then does. A blue screen is an instant death, for want of better words, and generally requires reboot manually.
Blue screens point to driver/hardware errors where system dumps point to software conflicts or memory overloads etc.
Just wondering if overheating could be a problem–first time it happened I had just thrown a sewat rag next to the laptop, and it blocked the vents. Maybe after an hour of running the graphics, it overheats???
Also, I am going from the serial port to USB2 though a converter.
On the computrainer website. This would explain errors as discribed including erros happening after delayed period likely when certain memory or thread is reached and causes conflict. Worth a look!
Some USB-to-Serial adapters made by Belkin (i.e., Model F5U409) and others may not communicate properly with CompuTrainer Software. If your PC does not have a standard serial port and a USB-to-Serial adapter is needed, we recommend using one that is offered from RacerMate. Order it here.
Ray at Computrainer/Racermate was very helpful for me last week. Depending it may take him a day to get to you, but we was able to walk me through an easy fix for a glitch I was having.
