I start off in ergo mode,and ride for 10 minutes(at 150 watts) to warm up the tire/generator.
After the warm up,I go back to calibration mode,start pedaling until I hit 25 mph,and stop pedaling .
Problem is I’m getting calibration values of over 5.00 lbs.
My rear tire has the proper air pressure in it,and I have the friction roller tight enough, were the tire isnt slipping.
I’ve had my CT for about 2 years now,and I never had an issue with calabrating until now.
Does anyone know what the problem might be?
Thanks
Does the calibration number change if you increase/decrease the roller tension? If not, or it changes erratically, you might want to check the DIN cable from the LG to the HC.
<<Does the calibration number change if you increase/decrease the roller tension? If not, or it changes erratically, you might want to check the DIN cable from the LG to the HC.
I tried increasing /decreasing roller tension,and my numbers still seem to be high.
DIN cable is plugged in properly as well.
You can try a new DIN cable. I had one go bad recently. Also check the RacerMate forums. http://68.115.203.26/phpBB2/index.php
