Friends dad has one that was still run on nintendo i believe. However his wattage numbers are off now by a lot my srm was reading almost lower then his CT. So i would at least get it checked if you know someone with powermeter.
Send it back to them for a refirb. Their customer service is the best. My controller stopped picking up cadence after 8 years of good use. I sent it back and for a very nominal charge they changed out the guts and sent it back. I was without the until for less than three weeks.
Yeah well when his daughter, that i dated for awhile, said she was doing 300 watt intervals i knew something was up. I told her there is no way or she’d have at least another 2 mph on her bike splits. so i went down and rode on it for my vo2 max test and one other step test and it was definitly off.
So how exactly do you check that? You just look at the power meter on your bike and compare it with what the CT is saying? Does the calibration have to be at a specific number? What is considered “way off”? Should they match up perfectly with the same number?
My coach is having me do this, I don’t own a PT, borrowing someones bike to stick on my CT to check the wattage for accuracy.
I had mine for probably 15 years, a nintendo unit. Then someone threw away some of the parts, but it was working fine. I bought another one. They are incerdible as far as duration, and you’re right…the numbers are only a reference…what counts is race day on the road. I e-mailed them for a problem, and they said at that point (new year’s), they were running 3 days in house! Keep abusing it.
I just did a simple test where I created a course that ramped up the wattage in increments. Then I downloaded the PT data, and compared it to the CT numbers at each wattage interval. I’m sure there’s a better way to do this, but I was just curious and wanted to see how the numbers compared.
11 years in the salt mine (basement) for my Nintendo version and still going strong. I thought I killed it last year but it was only a frayed wire that was quickly patched up.
CTs are not cheap to buy but they are certainly built to last. No complaints at all.
