Computrainer Ergo Mode MPH?
Are the MPH on the CT correct when in Ergo Mode? I usually average 16-20 MPH, but in ERGO at 185 Watts my heart rate was high but my MPH were only 10-12. How can that be? 10-12 MPH is nothing? BTW I am a female so don’t make fun of my Watts.
No it is not accurate really and it is not ideal to do a workout in that MPH range because the CT is most accurate in the 18 MPH range.
So what do I do to get it in that range. Change gears?
No reason to make fun of your watts - if the CT is calibrated correctly than 185watts is not exactly something to make fun of…anyhow, IMO eargo mode is fantastic and will build up your strength/stamina much better than if you just mindlessly ride the courses…so, don’t worry at all about your MPH but continue to focus on those watts and how they correspond to your heartrate. IMO the MPH are not accurate at all on Eargo but the wattage is and if you build on your sustainable wattage then the MPH when on the road will put a smile on your face. Just my 2cents worth.
yes - change gears. The mph is completely irrelevent in ergo mode. The load generator “maintains” the constant load regardless of what gear you are in, so you can ride along in 53x11 or 34x27 and theoretically the power that you put out will be identical (185 watts in your example) however the wheel will obviously spinning at a different rate (assuming you are keeping your cadence steady and not altering it significantly in response to the gear changing). Or at least that’s my understanding…
Thanks for everyone’s replies. I knew it had to be wrong, but it helps to have someone confirm it. The funny thing is that when I was doing my easy warm up in Ergo mode I was originally going 18-20 MPH. Then when I started doing intervals my MPH went way down. Oh and yes I did calibrate it properly. I calibrated until the pressure on the tire remained consistent. That took about 20 minutes.
