Computrainer - Acting up
Has anybody ever had their Computrainer continuosly drop from the race course into the options menu back and forth? If so, how were you able to fix it?
Mine has been working fine until about a week ago when every time I go to load or import a course and start riding it goes crazy after 5 second and it starts going back to the options screen and then loading the course again.
I’ve never had this exact problem, but I have had some similar problems. Take a look at what else is running on your machine while you are running the c-trainer program. My bet is that there is a conflict between the c-trainer and one of the programs you’ve got running.
To test this idea, close every program except the c-trainer. Next, go to the tray next to the clock and close everything you can. Now start the c-trainer and see if it is better. If it does work better, then it is a simple process of elimination to find out what is conflicting.
2nd idea, try running the c-trainer in window mode instead of full screen (F12 button I think).
3rd idea, go to the windows update site and make sure you have all the patches installed. Windows Media Player kept crashing my c-trainer until I got the latest patch.
Good luck
