Saving money and Alienware… never thought I’d hear that in a sentence together ![]()
I just bought an Alienware Alpha yesterday. I went with the i-3 with 8 gb of memory. I was torn between the i-3 and i-5 but seeing how this is really only going to be used for zwifting and running racermate one, I opted to save the money. Should be here tomorrow, I’ll let you know how it works out.
I was thinking of buying exactly the same for zwift next week, so will be interested in hearing if it works ok ![]()
Awesome. All the alienware alpha’s currently have the exact same GPU, so the cheapest one will run Zwift basically as fast as the nicer one. Almost no performance penalty for saving a little money.
Agreed. I’m running on an I3 desktop with 8 gb of ram and a nvidia 750 ti graphics card. This machine started with 4gb ram and the intel graphics. It would do ok like that. First I added the 8 gb of ram which did virtually nothing to help zwift. Then I added the 750 TI. Like a different game now. The game goes to High setting automatically with this card. I have manually altered the setting to the ultra settings and still get awesome performance.
Short story- don’t need cpu horespower - need GPU… I probably wouldn’t pay for a gaming PC if this one needed replaced. This low cost/low power consumption GPU has transformed a $300 desktop into a top of the line Zwift experience.
Got the computer saturday and starting playing with it later that day. It took some time but I finally got Zwift up and running. I’m not sure what my problem was but I had the hardest time getting Zwift to update/download after the install (I think it was my wireless connection but I’m not positive). The download/update error’d out on me a few times. It finally started to download for me but it said it was going to take over 4 hours. I switched to a wired connection and 10 minutes later, it was done. I’ve only been on once but so far I’m impressed. Graphics look good to me (for what that’s worth) and I didn’t have any glitches. I like how compact the box is.
Still unsure on why my wireless was taking forever. It showed I had 4-5 bars on my wireless connection.
Ordered the cheapest Alienware Alpha today. Got it for $479.
Saw this deal today and the alpha is $429 shipped: http://www.techbargains.com/alienware-alpha-deals#newsID446719
Can you send me the $50 since you were late with linking that deal? ![]()
I found it on sale right now at bestbuy for $399.
At first I was considering getting an inexpensive All-in-one that could handle Zwift, but after learning about Alienware Alpha, I may consider going that route. But would require me to purchase a monitor.
have you thoight of mini pc computers - like mini-x for example?
I’m a little confused about the alienware alpha. Since the computer doesn’t come with a keyboard or mouse, do you use an Xbox controller to use Zwift? That would be ideal (I think), but given Zwift isn’t part of Steam, I’m confused how this works.
Thanks,
Dave
you would just supply your own keyboard and mouse and use it like a regular PC
OK got it, thanks.
Obviously not a lot of gamers on here…
How do I snipe in Zwift?
I’m running Zwift on a 5 year old Dell XPS laptop without any issues. I’m not sure how you can see if it’s on High, Ultra or whatnot but I think the graphics are blurry when you’re pushing hard anyway lol. This laptop has 8GB RAM and an NVIDIA GPU of some kind. I think you’ll be ok with that bdget and like another user states, a new Dell is $479 and will work out of the box just fine.
WiFi has a couple components to a connection. Connecting to an Access Point (AP) gives you signal strength (measured in Received Signal Strength Indicator or RSSI), however that tells you nothing about the capacity of that AP - it could be constrained by a poor internet uplink (bandwidth constrained) , too many users attached to to it (connection constrained) , or slowed down by an old device forcing it into a slow compatibility mode… that is the dump truck in the fast-lane problem.
Run speedtest over both the Wi-Fi and Wired connections to see how big a performance hit you are taking.
I have two WLANs in my house - one ‘public’ one that I connect all the wi-fi connected appliances to (last count I was over 2 dozen) and a private one that runs only 802.11n for my performance sensitive devices. That keeps my thermostat from causing problems with my work traffic. Some higher-end Wi-Fi routers allow you to set up 2 networks for just this reason.
Hi All
Anyone know if the below spec laptop will be sufficient for Zwift? I have no idea. Im looking to buy a new laptop anyway but want to make sure it will be sufficient to also run Zwift
!(data:image/png;base64,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)
!(data:image/png;base64,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)
I’m running zwift on a $150 hp laptop with a celeron and 2gb of ram, outputting hdmi to a tv. It works fine.
However if I run it on a gaming desktop computer and put a movie on the other screen from the same computer, it goes to hell.
I am running Zwift with Kangaroo Mobile Desktop ($99.00) with Garmin ANT+, HDMI cable connection to my LED flat screen TV, and ANT+ keyboard/mouse. You can find the Kangaroo specification from the Microsoft Store. Just a FYI, I moved the Kangaroo with the ANT+ close to my Powertap P1 and that solved the on and off power drop out between my power meter and Zwift. I have just ordered a USB extension for the Garmin ANT+, so that I just have to only move the Garmin ANT+ next to my bike and the Kangaroo stays where my TV is mounted. I am running Zwift and music app at the same time and did not encounter any issue and it worked fine.
