I am thinking about getting some compact chainrings. I currently ride a triple, and have decided to buy a SRM with a double chainring. Not being a strong cyclist, I’m concerned that a standard double will be too tough on the hills. Looking at the compact chainring, I’m somewhat concerned about cross-chaining (small ring on the front, small cog on the back) for the gears I would aniticipate using on the flats. I could move to the large chainring on the front, but then I would be on the large cogs on the back (cross-chaining once again). Does anyone have any experience with compact chainrings, and cross-chaining? How is the shifting? How easy is it to trim? Any advice would be appreciated.
Don’t worry about it. I have a compact and think it was the best purchase I’ve made in years. Buy one!
These “concerns” will not be an issue for you. The only difference is that you will be able to ride in the small ring in a smaller cog, but you should not be riding past 6th cog (for 10 sp), if you are then it is time to shift to the big ring. If you are on the flats then most likely you will/should be in the big ring anyways. Realize that if you are past the middle of your cog set in either direction then it is time to shift to the other ring…then adjust your rear derailleur by 2 cogs. Usually this will give you a smooth transition with out a huge jump in cadence. Example, you are in the big ring, cog 7 (10 big-1 small). shift the front into the small ring and the back onto the 5th cog.
I use the SRM FSA model and have used compact on other bikes as well. The shifting is the same as with a 53/39 setup. Big - big will cause you some serious problems and little - little will make a lot of noise from the chain rubbing the derailleur. Really, there is much to be said about the differences in how the shifting system works, so go ahead and buy it! The cool thing is that the outer ring is capable of running normal rings (up to 60), and the inner can go up to 39t.
Regards,
I use compact chainrings on my tri bike (50/34) and the only thing i did was to shorten the chain a bit. I had no problems at all with shifting or anything else. I think it´s much nicer to ride on and i´m a decent rider, sub 5h at IM. You don´t need to ride big gears to go fast. But i ride my bike a bit different than most triathletes, 5cm set back and high cadence…
