Compact crankset
My road bike has a crankset w/compact drive 50/34T that I like. Would this work with my Tri bike with 650cc wheels? My Lbs salesperson said I would get dropped(I get dropped now).
You need a new LBS. You might go to a 11/23 cassette for the 650’s. Would probably be similiar to a 12/25 with 700’s.
Most triathletes are over geared. I use compacts with 12/25 on 700’s and am never going back to conventional cranks.
Thanks Cerveloguy I will start looking into it.
I think you’ll be undergeared with a compact crank on 650c wheels. You should be fine with a 12/25 cassette and standard crankset on the tri bike- that would be pretty close to the same size cassette and compact cranks on 700c wheels.
Agree. 53/39 on 650’s is roughly the same as a 50/34 on 700’s.
Did you mean to say 53/39 on 650c is the same as 50/34 on 700c
yes, thought I fixed that…
What is a realistic budget to switch to compact cranks? Does the entire setup with the BB have to be swapped out? I ride a 700 Dual with the standard FSA crank now.
Paul
You can use the same ISIS bottom bracket as long as you get an ISIS compatible crank (i.e. not shimano or campy).
I have seen them for sale on this forum for as little as 65 bucks. Put a WTB in the classifieds.
Dan
www.aiatriathlon.com
This is my gear chart for 650 11-21
If you ride between 19 and 25mph for most of your riding then this setup would work well for you.
   ring  cog    ratio    speed at 90rpm
1 50 21 2.38 15.6
2 50 19 2.63 17.2
3 50 17 2.94 19.2
4 50 16 3.12 20.4
5 50 15 3.33 21.8
6 50 14 3.57 23.4
7 50 13 3.84 25.2
8 50 12 4.16 27.3
9 50 11 4.54 29.7
Your LBS salesperson should do some homework
jaretj
"What is a realistic budget to switch to compact cranks? "
Ritchey’s are probably the cheapest. They use the standard BB’s.
http://www.nashbar.com/profile.cfm?category=&subcategory=&brand=1740&sku=15300&storetype=&estoreid=&pagename=
