So it is starting to get chilly here… let me just get this out there I am a cold wimp. My toes and fingers freeze on a ride and I am looking for a couple suggestions.
Gloves -
Shell or Jacket -
Socks or shoe covers -
There are a million items out there just looking for a quick suggestion. Usually never below 40 degrees for the most part.
Make sure you gloves and shoes aren’t too tight, or they get cold fast. I personally bought heated gloves, not cheap but I keep riding to -20C and my hands get cold at 0. I also bought some winter/water proof cycling shoes. Fully sealed up, so your feet do get damp, but so far they are fine for at least 1.5 hours.
I liked the old style neoprene shoe covers, but they aren’t really en vogue these days and those thin ones self destruct really fast, IME.
Jacket? I wear a rain coat with a fleece liner underneath. The key is to keep the wind out. This keep me commuting and riding all winter long. A balaclava helps as well.
Silk and wool are the best fibers for staying warm. Fleece is not bad.
I’d get some gloves that have a hard shell outer to block the wind. That’s probably the most important thing. Same for a jacket. Something that has a good wind blocking capability will help. I’ve found that tri shoes are somewhat miserable in the winter as they’re all highly ventilated. Neoprene covers seem to help quite a bit for me when combined with wool socks.
Nothings makes a brilliant sunny but cool or cold damp day, a miserable experience on a bicycle. Especially when it does not have to be. As the saying goes there is no such thing as bad weather, just bad clothing.
So I say invest properly and enjoy some fun fall or early spring riding (If you live in non snow locations even winter riding).
I live in So Cal, so my sense of Cold is relative. But Early AM on PCH in February or night or early AM rides before sunrise can be in the 40’s.
First thing forget the toe warmers (They are ugly, get in the way, do half of the job, and scream I am a triathlete who cannot ride a bicycle outside of a straight line). Get full on neoprene booties. No one has ever complained about their feet ever getting too warm. I like selections from Castelli (Narcista or Diliuvo) the best but I have a pair of Capo ISO Neoprene, as most of my cycling kits are one or the other of these 2 brands.
Gloves same thing and I hate wearing gloves and only do so when it is cold out.
Castelli Extremo’s for Cold 35 to 55. I did IM Tahoe with a pair of these and it was 37 degrees when we got out of the water.
Capo Piemont (My faves) 40 to 55. these are my go to’s typically for the winter Sat rides since I will only have them on for about 35 min on the flats, and on descents. They store in the back gear pocket on climbs or as the temp increases.
Next dress in layers and arm and leg / knee warmers
Baselayers. Get 1 with windstop. This will keep you warm without resorting to having to wear lots of bulky garments.
Vest. Same as windstop base layer, but you can open up for venting. Great if you are doing a lot of climbing open on the way up vent / zip up on the way down.
Arm warmers. Fleece is good. Capo Roubioux is the best IMO.
I typically do not go long sleeve jersey or jacket until it is really cold or I am riding at night or VERY early AM. I only wear these if I KNOW for a fact I will not overheat. Otherwise they are bulky, make you sweat to much and then you still get cold. Nalini makes one that I like where you can zip the sleeves off and turn it into a vest.
Yeah i think i need to get some “winter” shoes. My tri shoes are too tight to run anything but thin socks just being able to wear wool socks i think would help my toes. Good call on the hardshell for gloves. I have used cheepies from target and i may as well use nothing because the cold air goes right though them
40s? Seriously? Long sleeve jersey and a wind breaker. Anything long legs on the bottom, or just shorts and leg warmers. Any kind of gloves. That’s all you’ll need.
To stay a little more comfy add on a skull cap that covers your ears, and shoe covers (or just really warm socks if there’s enough room in the shoes).
Ah, you’re lucky. I think of 40F as the dividing line between ‘can ride as long as you want’ and ‘actually cold.’ At 40, I’d wear:
gloves- not necessarily cycling specific. These are what I’d grab from my closet: http://www.llbean.com/llb/shop/75619
jacket- either a nylon wind breaker or a softshell jacket. For example: http://www.rei.com/product/826563 http://www.rei.com/product/852904
feet- a pair of neoprene booties is the key. The cheap and ugly ones from Performance seem to be popular. Make sure they’re plenty big!
head- I use a buff often, it fits under a helmet. Or a skullcap that covers the ears.
thanks for the input… I did warn you i am a wimp in the cold! I usually end up freezing or way too hot… ill grab a few of these items and give them a shot! Thanks again
Yeah, I could only wish for 40’s today! It was in the low 20’s with a much lower windchill on my ride into work this morning. Had lots of layers on:
merino wool socksneoprene boots over regular cycling shoesknee warmersfleece lined tightsthin long sleeved wicking shirtmedium layer thermal shirtcycling jacket - the kind that looks like a jersey but are much thickerfleece vestbalaclavagortex ski gloves
Much colder and I would have gone with the plastic grocery bags over feet in shoes trick.
had this exact same inquiry but regarding running gear…any recommendations? (im in NYC, but I’m mexican so anything under 45 is cold with 30s being MUY PINCHE FRIO). thanks.
I’m an equal wimp in a cold pool, so I understand. I’m sure your local running/biking store has similar products to the ones I listed that you can try on. I listed those two jackets as examples of types of jackets you might find useful- a windbreaker type jacket ( but not Gore-Tex laminate type, those don’t work so well for running/cycling, we sweat too much) and a ‘soft-shell’ type jacket, which doesn’t need to by cycling-specific. I did buy those gloves exact gloves from LLBean (they have free shipping and I’m sure you could find a $10 off coupon with some digging) they’re good for the price, but I only get about 1.5 years out of them, and their biking sweet spot for me is the low 30’s, so they may be a little warm for you.
Move to Australia, 150km north of Sydney we average 17c (60f) as our max and rarely dip below 5c at night (40f), Although i still do feel cool as it’s all relative to what you get used to.
Try Tasmania (you know… where Tassie Devil comes from). Its “spring” here and we had snow 2 weeks ago.
To the OP - take up mountain biking and stop being a pussy, you’ll end up loving the cold conditions!! Plus the “interval” training on a MTB is great for off season work outs. Plus you get to buy a new bike
me too, just purchased two sets of running tights and looking for the best cold weather gloves.
The absolute best cold weather gloves are the brown cotton gloves from Home Depot or Lowes. The cost $1.50 pair and keep your hands warm down to 20 degrees. Buy 6 pair and throw them in the wash after each run.
