Budget constraints will not allow me to purchase a dedicated tri bike through next year. I’m wrestling with the thought of clipons. I’ve researched the web enough to see that many folks are claiming an average of 1.5 mph with equal effort (road bike with/without clipons)…makes me wonder enough to ask here, on a forum I trust (sic).
Can this be true; if it is, and I don’t have to make too many adjustments to the bike (Tarmac Pro which fits perfectly right now, although I’m toying with the thought of shortening my stem by 1cm), I’ll jump on the $250 for the HED Flip Lites right now.
As a crusty old fart who loves his roadie anyway, could this be the magic elixer, or internet hype? Up to 2mph faster is one hell of a jump.
The speed gains might be exagerated or an outlier. But yes, it’s worth it. I don’t know what your position is like right now and I expect that your back is about as low on the drops as it will be on the aero bars, but you’ll get your elbows in closer and have less frontal surface area since the arms below the elbows are basically removed from the frontal surface area.
If you can get a comfortable fit on your road bike with some clip-ons, then it’s a very good way to go and more people should give this a try if they only have 1 bike rather than owning only a tri bike.
When I put clipons on my road bike, I got at least 1 mph for free, no question.
Of course, it wasn’t too comfortable, certainly not like a properly fitted tri-bike. But it was definitely worth it.
I would, however suggest going with something a little less expensive than $250 clip-ons. I don’t think the extra $100 to $150 is necessary. But that’s just me.
worth it. depending on your base speed, if set up right, up to multiple minutes cut off of a 40 km bike leg. but you don’t need to buy $250 heds to get the gains. there are a lot of other choices out there.
I would say more like 2 MPH (from 20 MPH road to 22 in tri). I have a Soloist Team, so I angled the seatpost head to make the seattube angle steeper, got a Adamo and Syntace C2 bars, and it’s basically a tri bike now. I know they make a fastforward seatpost to give you a steeper angle…maybe go for a less expensive aerobar setup, get the FF and new saddle (if you need one).
I would look at any aerobars that have the armrests as low as possible for a road bike. You will not want them jacked up like the Syntace. I have HED Flip-lites and would say that they are probably the best option for a road bike. Oval is a good option as well. A710 or A910 clip ons are light and nice as they put the armrest low as well.
Flip-lites get the nod due to the fact that you can flip up the pads a bit if needed.
Is it worth it, YES. How much depends on fit and such. For my second road bike that I have set up with the HEDS, if I stay in the aerobars for my 30km ride to work with little wind, I can average about 1-2 mph faster than riding where I switch between hoods and drops. I have the extension cut a little shorter than I would normally run on my tri bike set up. I like the pads to sit right in the middle of my forearm.
