Clincher vs tubbie question
Velocity Spartacus Wheelset with Michelin pro tires is faster then my reflex tufo s33 tires wheels I have now .
Ok I an drinking the kool-aide.
I want to try clinchers
i can get a set of these clincher wheels cheep used .
do you think I will notice they are faster ?
is this OK training /race wheel for 168 lbs rider ?
I have a old uni cover is it to oldschool
thanks dirt
Do you ride clinchers in training? If so, then just do your own test of the tubulars vs clinchers with similar profile rims. You won’t notice that one is faster than the other just by feel; the biggest difference I noted was that the Tufos felt really rough riding. The clock is where I predict you will notice the most difference, assuming you can can do enough repetitions under similar conditions to draw a useful conclusion.
i don’t have clinchers wheels
just 32 spoke x 3 wheels reflex rims
how deep does a rim need to be to be a faster wheel ?
and how much time does a wheel with half the spokes (16 ) save ?
thanks thom
Yes…measurably so.
It’s not Kool-Aide…it’s more like Guiness
Yes.
Yes. The Sparticus uses a Deep V rim which is basically bombproof. It also doesn’t hurt that the rim depth is 30 mm for aerodynamics.
Yes…but oldschool is cool…
thanks dirt
De nada.
so you would try the uni cover ??
it is not florescent green or pink ha ha
thom
thom
Are those the fabric ones? If so, no…not unless it was a “retro ride” or something :slight_smile:
i will let you know how it turns out
wheels $ 100.
TIRES tubes $84. with shipping
so <$200. test
should I blow the wad on latex tubes ?
wheels $ 100.
so <$200. test
Why not? It’ll only be an extra ~$10 or so…
