Clear coat chip repair on carbon frame?
Looking for some suggestions on the best solution for repairing/covering a otherwise cosmetic issue of a chip in the clear coat on the top tube.
Thanks
Well, perhaps not the base solution Cosmetically, but I had my chain run off past my small ring and chip the clear coat on my carbon fiber. I used a hard enamel nail polish on it. Holds up good, easy to match color, and in expensive.
A super fine sand paper 320 -400 grit wet sand , tape off the small area . The best would be a 2 part urethane clear airbrushed on , but clear nail polish will work for small defects . Let it dry hard for a month use some rubbing compound and wax ,to get rid of any brush marks / over spray.
http://www.stewmac.com/shop/Glues,_adhesives//3/Stewart-MacDonald_Super_Glues.html
