I vary the “entry” speed at the start point (and thus, the stop point).
Interesting, for what purpose?
It lets you double-check the estimated Crr and CdA.
I have been working hard to get entry speeds consistent, in an effort to reduce the impact of error in the CdA estimate on the CRR delta between tires.
I just estimate both CdA and Crr simultaneously from the data. There are two unknowns, so you need (at least) two equations to solve for the two unknowns. Varying the entry speed gives you the two equations.
Got it. I remember this from your original VE paper and have tried it once before, though not too carefully.
Have you done direct CRR comparisons using this method? I’m curious how much precision you can reliably get for a delta CRR.
I think I actually am basically doing what you describe. I did a high speed run first to establish CdA using an estimated CRR. For the low speed run, instead of a standard VE test with the “zero elevation change low speed rolldownâ€.
The final CRR and CdA combination does have to work for both runs. Although worth saying… I was initially worried about relying on high- and low- speed runs for precision work because CRR and Cd vary with speed, and I’m doing much of the low speed runs under 10mph, where I think this is probably significant and hard to control. That’s l part of what led me to low speed testing, where CdA errors are less of an issue, and rolldown testing, where speed profiles between low speed runs are very similar, further minimizing the impact of errors in absolute CdA / CRR values on “delta CRRâ€.
Ultimately it’s actually not that hard to validate a delta CRR method. You can do runs with the same tire at different pressures, where you have a small but roughly known CRR change (say, based on BRR’s data at 60-80-100 psi). If the deltas you measure lines up roughly with what was determined expect from 3rd party CRR tests at different pressures, then I’ll consider it validated.
I had some luck with this validation with the CS2s on the first day. I’ll ultimately post the validation data along with final results when I can get another full round of good tests done.
No ETA on all this unfortunately.
