Chronic Loose Headset--Help Needed
I have tightened my headset several times, but it keeps coming loose. I am loosening the stem clamp bolt, tightening the cap bolt, and then retightening the clamp bolt. I suspect the problem is that the expansion nut inside the steerer tube is slipping. How tight can I crank that sucker down without damaging the carbon fiber steerer tube?
I won’t even attempt this one. Hopefully some of the better mechanics will show up with an answer.
One place you could try and get an answer is on the newsgroup rec.bicycles.tech. There are a lot of good mechanic types hanging out over there.
What make is the fork?
Okay…fork brand is NOT an issue
What HS you have?
Integrated?
“Ahead” style?
Needle Bearing?
It is a non-integrated FSA “Aheadset” type.
Not sure why R10Ti thinks that headset type is an issue? Hope he can enlighten me.
If the expansion plug is slipping, then tighten it. There are different types of expansion plugs, which are shipped with different forks. Eg Reynolds, just tighten that sucker hard in the steerer tube, and then use the top cap to tension the headset. Easton works a little differently, you just kind of press it in there, then tighten the plug and tension the headset at the same time. It takes a lot of winding as the spring between the cap and the plug compresses. The Reynolds is the better design IMO.
Make sure there isn’t any grease between the plug and the steerer tube.
"Okay…fork brand is NOT an issue "
Whatever… Have you had this problem before? I have. I would tighten my HS, head out on a ride, and by the time I was home it was loose again. Turns out my lock nut was slipping on my reynolds fork. I needed to tighten the compression nut inside the steer tube to 80 in/lb - I was not getting it tight enough by “feel” and needed a torque wrench. Once I did this, the problem went away.
If the brand of fork is Reynolds or Easton, you can tighten this by yourself, at home, just make sure the compression nut is tightened the right amount - look at the install instructions for this. Other brands are different - I remember someone telling me about one that needed to be glued in place with epoxy or something… I would go to your best local LBS and have them sort that out.
That is odd then.
What you may want to try is that if you have a carbon steerer tube.
  1. Make sure that there is no grease on the steerer.
  2. Make sure that there is no bladder in the steerer that is obstructing the pulling system.
  3. Take some light emery cloth and rough up the steerer just a small bit.
  4. Make sure you torque the stem bolts (they are tighter than you may think)
The top bolt, once the stem is on properly CAN BE REMOVED - that is not a bolt that needs to be under tension at all. Dont use that one to try and keep adjustment. It is common that if you have a bunch of spacers that you will get loose, try to have just one spacer - if you have 3+ smaller thin spacers in the stack. I would not think that this at all is due to the headset, that is unless the headset is being crushed (Stronglight). My guess would be that a new HS would not solve this issue - but a King is really really nice.
http://www.reynoldscomposites.com/Manual.pdf
STEP 7: "With a 6mm hex key, turn top cap clockwise to a torque of 22in lbs
**This step “preloads” the bearings only. Tightening the top cap does NOT keep the headset from becoming loose. Be sure to complete Step 8 before riding. **
To me, there is no doubt that if you are using the top cap as tension on the bike, and for more than pre-tension during installation, your HS is adjusted wrong. Often times the pre-tension system is with the fork, and the HS will come with the ever popular star washer that ONLY goes into forks with metal steerer tubes.
Yup, in my case I don’t think I was getting the bearings pre-loaded properly because the compression nut was slipping before the top cap hit 22 in/lbs.
That’s why I needed to tighten the compression nut to 80 (I think, maybe it was 70…) in/lbs. I believe that is step 6…
Thanks all. I really suspect it is the expansion nut slipping (it is a Reynolds fork), so I will try to find a torque wrench and tighten it. I am only using the top cap to preload the tension, but erhaps I am not tightening the clamp bolt tight enough. One problem I may also have is that particular stem (TTT Forgie) only has one clamp bolt–I prefer two for a better hold on the steerer tube. I will check out all the other suggestions as well.
And who says technical posts never get any responses on Slowtwitch?
Had this same problem on my carbon steering tube last year. I did what someone else already mentioned, roughed up the steering tube somewhat. Has not happened since.
That expansion bolt needs no torque after you adjust it. Matter of fact, after I adjust my HS, I take out the expansion bolt and recheck the HS with out it. I will then re-install the bolt just finger tight with low torque…just to fill the hole in my stem. I would suggest the sand paper plus a 2 bolt stem.
The Reynolds top cap has 2 main parts, the lower expansion plug and the top cap. Do NOT remove the expansion plug, its there to prevent the stem from crushing the steerer tube. The top cap can be backed off after tightening the stem, but not --I repeat NOT-- the expansion plug.
Good call…I only ever took out the bolt.
