I just finished a great workout on my CompuTrainer (got it for Christmas) and I noticed my rear tire is starting to get chewed up …again. My first tire last month lasted about 3 weeks and was trashed …so I put a Michelin Pro Race Slick on. When I am on the flatter courses it is fine …but today I was on a very hilly course (up to 11.5 gradient) and the tire is starting to make little rubber marbles. I always make sure to inflate the tire to 120 psi and I move the resistance wheel against the tire until it has very little slipage. Has anybody else had this problem and if so what can I do about it…??
What does it calibrate to?
Specialized makes a Flintstone hard tire the Armadillo. The worst riding tire on the road but will last much better than most tires on the trainer.
If you are chewing up tires that fast you either have the pressure too loose on the tire (tire slipping) or you have the bicycle misaligned. Check for both, one of them will solve the problem. One more thing, always use an old tire on your trainer. Trainers do wear out tires faster than the road.
Keep in mind that once you get warmed up the actual pressure in the tire will increase (hot air balloon concept). You may want to start at a lower psi and slip for a few minutes (when you should be spinning easy anyway) and save your tires.
Rocketboy
Buy the cheapest tire you can find…wire bead and everything. The softer rubber compounds on race tires can not withstand the heat and pressure that a trainer puts on them. All LBS will have cheap tires that will work great…like $12-$15.
I get several thousand miles out of my michelin pro race tires on the c-trainer. In fact, I sometimes ride them outside for 2k miles, then inside on the trainer indefinitely.
I encountered the same thing once, I cleaned the tire and roller with alcohol. Increased rolling resistance and ensured alignment of the bike on the roller.
I keep hearing about trainers eating tires, but I don’t understand. how much riding on the trainer are you people doing?
last year I put in about 85 hours on my kurt kinetic road machine. the year before I put in 72 hours. 3 years ago, 56 hours. 4 years ago, when I first got the trainer, probably in the 40+ range.
all of these hours have been on the same tire, a michelin axial pro. and (what now seems to be incredible after hearing all these tire eating stories) this was after the tire had about 2500 road miles on it.
what am I doing right? I’ve saved some more tires that have served their useful life on the road, but haven’t needed them yet. I’m almost scared to change the one I’m using…it may throw the universe out of whack.
