Changing Integrated Fork
I am looking to change the Reynolds fork on my Saber to a Ouzo Aero Pro. I am having a hard time finding on for the integrated headset. Is this a special order or will a normal fork work? Thanks for the help
You will need the Ouzo Pro Integrated…should be quite easy to find. I also know that Alpha Q has some new special where if you get their fork they will give you a free carbon seatpost…
The fork should be the same regardless if you have an integrated headset or not. The integrated headset just uses the frame as the cups for the bearings rather than pressing cups in after the frame is complete. All the major manufactures campy, fsa, shimano etc. make integrated headsets. The part that matters on the fork is the size. It needs to match your frame either 1” or 1 1/8” Why don’t you just re-use the headset you have?
I read up on the Ouzo forks. I think you are thinking of the Ouzo pro integrated fork. They modified the crown diameter to 45mm. This is the only fork they do this on. The aero fork doesn’t provide this option. I was able to find them at www.competetivecyclist.com. I can’t find anybody that see’s this minor change as an advantage. You will pay a weight penalty for the mod.
reynolds doesn’t make the ouzo aero pro in an integrated style, but like the previous poster mentioned, it doesn’t matter. a standard ouzo pro aero will work just fine with an integrated headset according to the tech folks at reynolds. it just won’t be as purty.
