I just did the 30 min run time trial for LTHR (ave of last 20 minutes) and found a significant change from the last time I did it.
The last time I did the test (last June) I was at 168, now I’m at 179 which coincides with my PE’s for my runs much better. Also it is about 13 beats higher than my tested bike LTHR so that seems about right too.
Has anyone else seen this big of a change in a 6 month period?
Last spring and summer I was running LSD forever, now after IMFL I have put interval workouts and tempo runs into my schedule. I feel much faster and more efficient but with a slightly higher HR. Will these speed sessions affect my LTHR that much?
I kind of did a pre TT last weekend and got a 175 for the last 2 miles of a tempo run so I have a lot of confidence in this number.
What really matters is your speed at your LTH. Are you running faster. If it was 168 and you were running 6min mile pace now it’s 179 and your at 5:57 pace then somethings wrong and you have not improved. But if it is 179 and your running 5:42 pace then that is a better result. Often you will not see a change in LTH but your speed at LTH keeps getting faster.
Before I was running at 8:20’s (roughly) at the 168, yesterday I was running at 7:20’s at the 179.
This sounds like the test that Joe Friel has made popular. It’s a pretty good one if you follow the directions, which include running as fast as you can sustain for those last 20 minutes of the test. You should feel completely wiped at the end.
If you ran all out both times, it seems to me that your lactate tolerance level has gone up. As a result, you’re able to run faster for 20 minutes than you could before.
If you run 8:20 pace now, what’s your average HR? Is it still 168, or is it lower? Should be lower, showing that your cardio system is more efficient. If not, that indicates that you haven’t improved much from training.
When you were running 6 months ago, were you able to sustain 7:20s for 20 minutes? If so, you were sandbagging the first time trial! Was your HR 179 at a 7:20 sustained pace? If your HR for 20 minutes at 7:20 hasn’t come down, that indicates no improvement from training.
Lee Silverman
JackRabbit Sports
Park Slope, Brooklyn
I ran 7 miles today and averaged 8:30’s at 159bpm. I don’t think that an extra 10 sec/mile would have jumped me up that far, it may have gotten a little over 160.
6 months ago I couldn’t run anything much under 8 min/mile without having to stop for a breather. If I had tried to go faster I would have only been able to do about a mile.
