I have a hilly bike race coming up and I was wondering if it is possible to change the front gear rings for a lower ratio instead of the expense of a compact crank set ?
Thanks
Thanks
You can run 50/38 rings instead of 53/39 on a regular crank. My wife does that.
will most front derailleurs shift well in that setup?
Or will you then need a front der for a compact crank?
just wondering…
-charles
just wondering…
-charles
They shift fine… it’s not unlike some CX setups and my kids run 38/48 (to comply with junior gears) and they shift perfectly.
I run a 50-34 on the front of my road bike. I use a standard front Der. with 180mm Rotor Cranks. It shifts perfectly.
I also run a 53-34 on the front of my Zipp 2001 TT bike. I use a standard front der with 180mm Rotor Cranks. It shifts perfectly. Though you do have to watch a small amount of chain bounce when shifting from the 53 to the 34.
Perfect adjustment of the front der is required for these setups, but since I’m a bike mechanic I dont have any problems.
I use this gearing since I live in the mountains. A day with 2000 ft. of climbing is my “flat” day.
Thanks for clearing that up, Shimano sell these smaller rings or do I look at FSA etc?
You’ll need to check on your own. All my bikes are fitted with Rotor Cranks. The RC rings are Rotor Crank proprietary 4 bolt. I’m sure FSA or Shimano make the 34’s or about there.
Check out speedgoat.com - they carry a very good supply of chainrings in various sizes and bolt configurations.
Also check out this thread - I was doing the same thing (switching front chainrings) a few months ago, and there’s some good information in it. http://forum.slowtwitch.com/gforum.cgi?post=1017979;search_string=front;#1017979
Your bolt pattern on a 53/39 is probably 130bcd. Most 50/34 ring set-ups use a 110bcd. You should be able to find 53/38 in 130bcd though.
It should shift fine, most derailleurs are made to handle a 14 tooth difference–16 is pushing it and that’s why some people have issues with a 50/34 if it’s not adjusted properly.
AEBike.com has good parts inventory as well.
Check the Salsa rings on Excel Sports Boulder – they make a 38T on a 130 pattern.
What cassette are you running in back? 9 or 10spd?
You have several options…one being a MTB cassette.
I have 50/38 on my bike. Shimano DA10 crankset with FSA chainrings. I think I got them from Jenson USA. Had to make some minor adjustments to the F Dr and chain, but if shifts fine.
