I dont think you can go wrong staying with the DA. Tried and true right? I am thinking about going with a wipperman with connex on it for ease of cleaning and smoother shifting. Just not sure if it will work with the D.A. , FSA compact Light , Qring combo. But I guess if you dont try you do not know. You can always go back.
A 7800 crankset is marginally better than Force… However, BB30 is better than running that 7800 crankset with the adapter. So, you’ll either be the same, or maybe a little better going to a true BB30 crankset. Going to a new dura ace or Red BB30 would be the best of both worlds.
I am running a force BB30 set with everything else 7900. Could not justify the extra hundred buck for Red when they are essentially the same weight anyhow. I like the BB30 but do not think that I could possibly “feel” the difference in any set up. Shifts great.
If they were each non BB30 cranks, the Force would probably be a downgrade from the 7800.
However, since BB30 cranks are usually slightly stiffer, possibly lower Q factor, lighter and you get to stop running an adapter; I would personally make the switch.
Just put a connex link in your DA chain. That’s what I do and it works perfectly.
