on a 20 speed any difference on which chain to buy? there was an article earlier around that Slowman said he liked the wipperman chain but it was awhile ago any new thoughts thanks
I recommend the KMC chains. I use them with Shimano drivetrains, and have found that performance excellent, and they are quieter than shimano chains.
I just did some research on chains since its time to change all mine.
Lots of reviews on the Wippermans are not very good. Lots of reviews and stories of them breaking very prematurely.
I’ve been using SRAM for many years. They shift very well and I’ve not had a single problem. They seem to last longer then the Shimano chains I used to use.
I’ll stay with the SRAM.
I use Wipperman on my Campy 10, I’ve never had an issue with breakage on them. I have however broken a few Campy at the end of the season when I was using them.
KMC on my Shimano 10, I like the fact that I can take the chain off to clean. It also seems to work better than the Wipperman on the Shimano drivetrain.
SRAM on anything 8 or 9 speed.
My wife & I both purchased new bikes last year–both with DA10. Mine has the shimano chain: the only thing I don’t like is that I can’t remove the chain to clean it. My wife has the wimmerman: neither I nor my LBS can get the bike to run silent in all gears. My LBS says it is the chain. As this is a popular combo, it is probably a fluke so read into it what you like. If a second LBS can’t figure it out, I will get the shimano chain.
SRAM - love 'em, especially the quick link.
Just bought a SRAM hollow Pin Chain last week! Was riding a Shimano before that! I agree that after reading all the reviews and talking with the LBS and my other half, Glyn that SRAM is the way to go!
jumped in for the sram 10 speed hope i like it thanks
“Lots of reviews and stories of them breaking very prematurely.”
posts like this represent the problem with the internet. wippermann got a bad batch of stainless steel from sweden that went into its stainless chains two years ago. the problem was specifically related to THOSE chains, only the stainless, only that batch. that would’ve been known to you had you searched wippermann on this forum.
wippermann is probably the best maker of chains for bicycles worldwide, that bad stainless batch notwithstanding. however, SRAM also makes good chains. my SOLE problem with shimano’s chains, campy’s chains, and the like, is the connecting mechanism. in my opinion, the problem is not only the relative ease with which one can connect a chain incorrectly, but also that you can’t remove the chain from the bike to clean it.
i’ve got no problem with shimano’s chains, as long as they are used with a link such as that by wippermann or SRAM. wippermann’s connex link is now available as a link only, for such use. or you can buy a wippermann chain, and the nickel chain is fine. i’ve never heard of a single breakage of a wippermann nickel chain, tho i myself have popped both a campy and a shimano chain while riding. any and all chains do, i’m sure, have a certain amount of breakage, and even tho i’ve popped campy and shimano i’d continue to use them. but with this proviso: i’d use them with the connex link that’s appropriate for whatever chain you intend to use.
all that said, shimano chains are used around the world with great success, with shimano’s link mechanism. so obviously shimano chains are fine. but my own preference is to use wippermann’s connex link with whatever chain you might ride.
I’ve tried really hard to like these chains…I broke the first one I had (and I’m way too small to be breaking chains), so that left a bad taste in my mouth. Still, I heard that was an isolated deal with a bad batch or something, so I tried them again. This bigger issue is that shifting performace suffered with the chain, to the ‘unacceptable for a mass start event’ sort of shifting.
I’ve got enough things to worry about–I don’t need to be wondering if my bike’s going to shift in a sprint. I do like the Connex link, though. I’ve used the Campy one on a Shimano chain w/no problem (and I think it comes in a ‘Shimano’ version now). The Shimano chains don’t seem to last as long, but the shifting seems WAY better. I have no idea why this is, but it’s been my experience, and that of some teammates as well.
UPDATE : went with SRAM in feb and already in june i need to replace as it is @ 9 on the chain tool. about 1000 miles and chain is gone. is this to soon or about right i am 210 lbs and do climb a fair bit if that makes a difference
well i once went through my chain in just over 1 month. But that month i put on a lot of miles, because for some unknown reason, I decided to train with two different guys that where going to Kona. and they put on the miles. Well also we did a lot of hill climbing, and all the hill climbing we did was big ring hill climbing. you will be amazed at the hills you can climb in the big ring at a cadence of about 40!!! I was also told that crossing(going big ring to large rear cog and small ring to small rear cog) the chain will also wear it out faster, best to stay in the middle of the cassette. That was the only time i have worn it out that fast. But i do ride a lot of hills and I also ride the trainer a lot for intervals. And they tell me the trainer also wears down your chain. not to even mention the tire. I almost had the side wall blow out on one of my tires the other day and I wasn’t on the trainer.
Interesting info on that problem with the stainless Wipperman chain, I had a stainless a few years ago on my trainer and I noticed a few of side plates had cracks in them !!
That kept me from getting them again, maybe time to try them again.
Ron W.
