Ok ST crew I am in need of advice.
I took my bike into a new to me LBS. Recommended by a friend who is a great coach. I brought the bike in to be re cabled, mostly because when I built the bike up I left the cables too long and as I dropped the stem the cables just looked sloppy.
I show up to pick the bike up and I get a stern look and essentially a bit of a lecture about my drive train.
I am told I need a new chain and cassette and I really should replace the chain rings. Explanation was that the chain 2,200 miles on it was pooched. That part I buy. Next was that since the cassette too had that mileage and also the chain rings they were likely toast too. He said they wear together, which I do understand. I have worked on motorcycles for years and know that when you replace chains you usually want to replace sprockets too.
He said had I checked my chain length more frequently and replaced the chain earlier I would have been ok to just replace that.
What I cannot figure out is… if my drive train is so pooched, why does it still shift like the day I bought it? I would think there would be some kind of poor shifting if everything were a total loss.
As stated 2,200 miles on the drive train. Chain cleaned and lubed every 150-250 miles or so. Shifting is fine.
Should note the components are Ultegra 6700.
What would you do in my situation? He is telling me if I put a new chain on now (which I already have mind you) that it will wear out in a month.
I see no visible wear on the cassette teeth or chain ring teeth.
Thanks in advance, Cheers
