What would be the expected life of a 100% CF tubular carbon wheel, let’s say by a lightweight rider (60-70 kg)? The hub and spokes are serviceable, but my main concern is the actual structural life of the wheel and the braking surface.
Here’s an example, the braking surface on a 3000 miles tubular EA90.
I would contact Easton specifically about brake track life. As far as the structure of the rim goes, in theory it should last longer than an aluminum rim IF it’s properly manufactured. However, if it is damaged you need to toss it. I think certain shops can inspect CF now with ultrasound/infrared but I could be wrong (there’s something on Calfee’s website about cf inspection).
re wet braking: don’t expect it to be very good. If you’re lucky it will be “adequate”.
I don’t own a set of carbon rims, but I believe their pad compounds are made to be ablative to keep the rims from getting too hot. That might also reduce the amount of wear to the rim compared to aluminum pads and rims.
