Cervelo Soloist Seatpost Setback?
How much setback in seatpost when using the rear facing (road) clamp position?
The exact seat tube angle would depend on your seat height and position of the saddle. I believe generally, it’s around 73-74 degrees. (the Cervelo website has the exact numbers per frame size)
There is also a calculator of sorts in the tech section of the main Slowtwitch site that uses the seat height etc… to give you a more precice measurement. I’d try that.
Excluding saddle height and angle, does the clamp not have an inherent amount of setback, i.e., 1.5cm or 2.5cm, etc.?
