New to the Board and am seeking advice on setting up my Cervelo for TTs.
I have a 48 Cervelo SLC SL. (sorta blew the budget on this bike and can’t afford a dedicated TT bike now).
The SLC SL is set up with Zipp SLC2 road bars. I have the Zipp Vuka clipons on order. I have a spare seatpost that I will mount a Selle Italia SLR T1 on.
As far as wheels go…I have a set of Reynolds DV46UL Tubulars. I attached a picture of the bike with my other wheels on it. The only thing I have changed
since the picture was take was the water bottle cage on the downtube. I added a Arundel aero bottle/cage. Its very difficult to fit 2 normal water bottles on a size
48 frame. A little info about me I suppose may help. I’m 5 foot 5, 68.5kg (hoping to get to 66 someday). I train with a powermeter and I have access to tacx trainers with powermeters.
My last “indoor” TT was 15 minutes and my average wattage was 291.
Any advice/criticism welcome.
regarding the clip-ons, just make sure your carbon drop bars are design to accept cip-on aerobars. Ask Zipp if you’re not sure. Not all carbon drop bars are designed for clip-on clamping stresses.
It looks from the pic like you have a good 6-7cm of drop already. With a forward seatpost, and maintaining saddle-BB distance, you should be able to squeeze out another 2cm of drop or so, making handlebar drop 8-9cm. So you should have a fairly decent handlebar drop for TTing purposes.
The bars on the SLC SL now are Zipp SLC2. I purchased the bars specfically to bolt the Zipp Vuka ClipOns. So I should be all set there.
Actually the drop right now is a little too severe for stricly road riding. I had to add a small spacer and move the bars up just a touch.
I’m not sure if I will take the spacer out and drop the bars down for TTs. I will find that all out this week, after my fitting.
I’ll be sure to post pictures!
