I am 6’2" with a 33 to 34 inch inseam. Do you think a 56 Cervelo Dual frame would fit?
I’m a similar size and have a 56 cm P2SL. I certainly wouldn’t go bigger. In UCI legal form (seat 5 cm behind BB), I find the top tube a little long and am going down to an 80 mm stem this season. If I slammed the saddle forward like a triathlete probably would, the size would be about right.
Thanks for the info. That is what I was looking for. I know that sizing is case specific, but I wanted to get a general idea of whether it would work.
I’m 6’2" with a 35" inseam. I’ve been told to go with the 58.
Who knows?
Lemond formula says I need a 66cm cockpit.
If I run the dual at 78°, then the size 58 would be about right (eff top tube 56).
If I run 75°, then I’d have to have a really short stem (eff top tube 59).
Thanks. A 56 would be put the eff TT at 54.5 if you are running 58 degrees and 57.3 if you are running 75 degrees. Something in the middle would probably work for me. My road bike has a 57 top tube, and I feel like I am stretching out a little bit.
I am 6’1" with a 32 inseam I ride a 56 P2c tried the 54 but it seemed to small. Very happy on the 56.
I am about the same size and tried a 56cm and 58cm P2k and fit fine on both of them. I ended up getting a 58 P2C.
