I bought a nearly new Cervelo Dual privately and on my first trainer ride it became apparent that I need to slide the seat forward a bit. I don’t need to flip the seatpost, just loosen up the two-bolt seatpost clamp and push the seat forward one or two cm. The problem is the bolts. One is an allen key which is fine. The other is a round head with knurled edge. I can’t believe they expect me to turn this with my fingers.
Can anybody give me a tip as to how I can turn this second bolt without ripping my fingers apart or damaging the knurl?
i’m right there with you.
it’s insane. it’s doable, but not fun; and it’s hard to be precise. basically, once you get the thing kind of tight, you need to tighten the other one, which tends to change the angle. very aggravating.
great bikes with lousy, lousy seat clamps.
-charles
You only need to loosen the allen head to slide the seat forward.
The knurled head is for setting the angle (nose up/down) of the saddle, and should only be adjusted (in very small increments) when the allen head is loose. Yes, it’s a pain and will likely require you to tighten/loosen the allen head a few times to tweak it just right. But, once it’s set, you shouldn’t have to mess with it again.
Wow! This was my first post on Slowtwitch and I am humbled by how fast and helpful the responses have been.
I’ll give that seatpost another shot, seems like the hex bolt is the one to loosen up first (which I did but seems the threads were grabbing the clamp so it wasn’t actually loosening when I tried it yesterday) and I should be on my way.
