Cervelo S series
If the nose is missing then how does it allow for a more forward position?
Pardon me, but what do splitters do? And what’s different about the newer frame that makes them easier to switch? I don’t have any experience with bike building and stuff so all these is a little foreign.
Why did you choose to use the PD saddle? It allows a more forward position I assume? If 20mins is all it takes that would be fantastic :slight_smile:
Hmmm…lemme do my best to explain as simply as possible.
If you look just above the “o” in the Cervelo logo, there is a black aluminum piece. It is located where the downtube shifter bosses would be on an older-style steel frame. On the inside of those pieces are the cable housing stops for the shift cables. It was kind of a pain to get it set…too much of a hassle to do if I was gonna regularly swap the stuff around.
By using the cable adjusters, I can leave a section of housing in place between the internal stop and the adjuster / splitter. I then only need to loosen the bolts on the derailleurs (and brakes) and pull the cable all the way through as I remove the HB set up. The other HB set up has a full set of cables, but only enough housing to reach the adjusters / splitter. I then thread the cables down through the housing left sticking out of the frame, pull them out through the access hole near the BB and atach to the derailleurs.
The first time you set up each HB configuation, it will take considerably longer than 20 min. But once you have your lengths set, etc. chaning things over is pretty simple.
NOTE - you will need to solder or Krazy Glue your cable ends to do this. If you use traditional cable ends that are crimped on, you have to cut them off, eventually making the cables too short to thread back through.
Kinda long-winded…hope that made sense. if not, lemme know.
Oh, right…PD saddle.
Bought it out of desperation on Spring Break. Had been riding a first-gen Fizik Arione tri saddle (not the Tri2 version) and it was killin’ me. On Spring Break this year I could not stand it anymore and went to a local shop in FL for a new saddle. They had the PD saddle (as well as Cobb), it was significantly less than other options and very well padded on the nose.
Doesn’t get the love that Adamo or Cobb gets, but I have been very pleased with it since I got it. But saddles are very individual things…what works for some doesn’t work for others.
In short, because that “missing” 2.5 inches is added onto the back of the saddle (solely to comply with the UCI minimum saddle length requirement)…and thus, the saddle rails extend much further back (relative to the place you sit on it) than on a typical saddle.
Couple that with the fact the proper way of sitting on the saddle is to place the “sit bones” on the prongs, and “Voila!”…
I’m kind of getting it, but then all these is still pretty foreign to me so it will take a while. Thanks so much for your help! I will certainly read back on these once in a while, maybe when I have first hand experience it would make more sense to me.
Ah I see. Would a saddle that is further forward be equivalent to a steeper seat angle?
I’m still trying to think of how I could use the S5 frame for a TT bike, mainly because I don’t want to have any excuse to change bikes in future and I think with a TT set up the rear wheel cut out of the S5 would look better than the S2 :slight_smile: I don’t really want to get 2 bikes for a few reasons, so the P2 + a road bike thing won’t work out that well for me. And I dont mind the trouble of switching cockpits once in a while. Also, seeing as how jackmott said the S5 is about as fast as a P4…Of course, I don’t want to compromise on my TT position too. I guess I’m asking for too much :stuck_out_tongue:
Just consider that I figure in order to make an S5 work as a TT rig for me, I’m going to need to source a 120mm, -45d stem…
edit:…and yes, a saddle further forward, by definition, is a steeper seat angle.
Sadly I don’t know my numbers and can’t run the same calculations. I’m fitted poorly on my current bike so won’t help to get anything from there.
You are sure to get many stares if you set it up with that stem…
I’ll start out with my Look Ergostem to get the exact dimesions dialed…that’s the same thing I used to do when I used my aluminum Soloist as a TT bike…
You need to define what your priorities are.
  1. If you are looking for a kick ass, best in class road bike and you road race - then get the S5. I just spent three days riding one and it’s all of what I said in the first sentence.
  2. Don’t retro-fit a road bike for tri/tt UNLESS you can actually make it work with minimal modification. Some can actually do this with shortie aero bars and moving the seat *slightly *forward. It’s about body morphology. A long torso, flexible lower back and hip flexors are key. More than a few can’t to this. Many try, though and the results are not good.
  3. If the road bike is just to have a road bike for training, for group rides, then why does it need to be aero? Save all the aero toys for the Tri/tt bike and get a basic road bike. In the Cervelo line that would be the R series bikes. Yes that means having two bikes!
Unless there is no way you can get low enough with the S5 geometry, I don’t seen any reason to ride to choose the S2. The s5 is faster unless you “need” a lower position.
Even ignoring the stack, the geometry is different. Don’t know how much that effect things like handling, but it will have some effect. Beyond that do you have any data theat a S2/3 with horizontal stem and 00 spacers is less aero than a S5 with a negative stem, in front of the aero headtube? I’m perfectly willing to concede the bare S5 frame is more aero, not so certain that the built bike is always going to be more aero.
Alternative 1: S1 (used) + P2
Cheaper than a S5 and much faster, if you use your time for riding instead of changing cockpits.
Alternative 2: P2 with road bars and clip ons (Team TBB style)
How about those 2 choices with a person’s hands/arms on the bars blocking off the stem area anyway??
I’ll put my money on the S5 in that situation…literally :wink:
No idea, I’d like the see the test done though.
Congrats, do you have an ETA?
even on a bare bike I would be surprised if moving a bit of stem in front of the head tube added 92 grams of drag. Napkin math would suggest it would be an order of magnitude less than that. like maybe 10 grams.
Soon :slight_smile:
Soon :slight_smile:
i figured you were going to hold out for the new cervelo and get that cda to <0.200!
Soon :slight_smile:
Who says I won’t be able to get there with an S5?
Besides, I’m such a roadie I can’t stand the thought of not having those same advantages when I’m road racing as well :wink:
