Cervelo Road Geometry
I am 6-2 1/2 with about a 35.5" inseam and about 170-175lbs race weight.
I ride a 58 cm Caad 5 Cannondale frame with a 120mm bar stem, and I am close to ordering a 58cm Cervelo R2.5 frame and buying a Dura-Ace 10spd build kit.
The website says “stack” and “reach” are most important. I can figure out the stack but I can’t figure out the reach. The website shows the reach measuring to a different point on the head tube then the toptube length, it appears the inside edge of the tube and not the centre of the tube. But it is confusing and the diagram is not clear. (Non-related - Cervelo also use an odd toptube measurement from the back of the seattube - perhaps this is to account for the sloping top tube?)
The stack is almost identical between the 58cm Cannondale and the 58cm Cervelo (within 2mm), but the Cervelo reach is short by about 7mm cf Cannondale if I measure to the middle of the head tube. If I measure to the imagined inside edge of the head tube then the Cervelo reach is about 13mm longer cf Cannondale.
I don’t want to go to 130mm stem if possible, as I am using a 120mm stem right now. Any thoughts? Any 6+ footers with a 58cm Cervelo Soloist or R2.5 frame (they supposedly fit the same…) Is stack more important than reach or the other way around.
There are no R2.5s locally, they are on order so I have nothing to compare with.
(FYI, the 61cm frame has a significantly higher stack than the Cannondale (19mm) but the reach is about the same)
Any help is greatly appreciated.
Why the reluctance to use a 130 stem. You’re fairly tall, a longish stem won’t negatively effect handling. It actually may improve handling by placing a little more weight over the front end.
Also, you need to know either the seat tube angle, setback, or both to fiigure out and compare reach and effective top tubes. For example, two bikes with the same tt length but different seat tube angles will have different effective tt lengths. The bike with the steeper sta will be shorter than the bike with the shallower sta.
  1. The reach is measured to the center of the headtube but at the top end of it, so where the headset dust cover starts. The toptube is measured to the center of the headtube but where it intersects with the toptube, fairly standard practice. so they both measure to the center of the headtube, but at different “heights”. This is so that stack and reach measure to the same point, together they are the distance from the bb to the top of the headtube split up by horizontal and vertical component
  2. Our toptube measurement is done the only way they make sense, to the actually effective seattube angle. This can be at the front of the seattube or at the rear, or not even on the seattube for that matter depending on the seatpost you use. But regardless, they are measured horizontally from the toptube/headtube intersection back. This is also a fairly standard practice, there is no point in measuring it along a sloping toptube as you wouldn’t be able to compare it to other bikes that way.
Gerard, in an earlier post, you indicated that the average height of a regular customer was…
"Tyler is 5’8 or 5’9, and he was on a 54cm R2.5. So if anything, he was riding a frame a tad above average, as I would say the average height of regular customers with a 54cm Cervelo (R2.5 and Soloist have the same geometry) is 5’10. "
What about average heights for the 58cm and 61cm frame? Just looking for more validation… ;^)
Unfortunately at the higher end of the range the variance is larger, we see anything from say 5’11 to 6’3 on a 58cm frame, whereas 61cm starts as low as maybe 6’1. There is more seat to handlebar drop to play with so the spead gets bigger.
