Cervelo road bike vs. Tri bike sizing
So who has both and what sizing are you riding on them. I’m on a 54 tri bike. Would a 56 be good or a 58 be better?
Grant
They claim to size both the same way. IMO I ride a 54 cm tri bike and would ride the same size Soloist/R3/Prodigy. Of course this depends upon your body measurements/flexibility.
If you ride the tri bike in a slack TT position you may find the top tube a bit long.
I ride as forward as you can get so i think a 56 may work.
Grant
Go and get FIST’ed by a Cervelo dealer!!
What else can I say.
Ahh but that costs more. Im on a budget.
Grant
Can’t be done. We know nothing of your dimensions or flexiblity, etc.
http://i3.photobucket.com/albums/y85/iceeagle2102/Cervelocritique1.jpg
6 foot tall. Thats the best i can do if you need more dimensions i can get them.
Grant
My son is 6’ 2" tall and rode a 58 R2.5, then Soloist carbon last year, both with an 11 cm stem. He has a friend who’s shorter (maybe even under 6’) and he’s on a 56 but using a 13 cm stem. I think a 54 would definitely be too small.
I was leaning more towards a 56 anyways. 95 percent of the reason i have a 54 in the p3c is headtube size. The other are just way too tall for me.
Grant
cyclonehockey21,
I’m unfamiliar with how Cervelo measures their top tubes for their road bikes vs tri bikes but frankly, I’d be surprised if you went from a road bike to a tri bike and move to a longer top tube.
That being said, there are plenty of people riding frames that are too big (too stretched out) for them because they didn’t bother to get properly fit by a “qualified” fit specialist before purchasing their tri bike.
But don’t let that stop you from adding your name to that long list. You can buy that 56 or 58 and get the great “deal” that you just don’t want to pass up. By the way, the dealer doesn’t have any 54 or 52 06 models left, but he said you could fit on the ones he did have left. When you finally admit that your bike doesn’t really fit you properly and is in part responsible for limiting your performance, then you can finally purchase the right size tri bike that you originally believed was way too small (simply based on the fact you were riding a road bike frame that was “xx” centimeters big and you just couldn’t accept that you would ride a tri bike that wasn’t at least that same size or bigger).
So let’s see…buy 1st bike and get a “good deal” even though it turns out to be the wrong size, then finally buy correct size bike. Buy two bikes to get correct size bike. Yep, sounds like a good deal to me! Go for it. At least you will be helping to keep the LBS is business. That counts for something.
Can you not read or do you just want to sound cool?
I have a tri bike that fits perfectly, that i fit by myself. I am going to a road bike that i am going to use when i move to colorado to train on in the mountains. Actually the dealer here can get whatever i want in but i’d rather save some money. Nice try on that one too.
So how about you read before you assume im buying a tri bike. You could just help out like c50jim did above giving me two people that he knows who rides cervelos and how tall they are and what size they ride. But that might be outside your realm of being able to help you’d rather be sarcastic because of course sounding like that is really cool.
Give me a break. Actually i used to have a 58 trek roadbike that fit me fine. I just wanted to see if i should go with 56 in a cervelo or a 58. Cause guess what i could change the stem woah watch out thats difficult.
But thanks for you amazing help on getting me to get sized on a tri bike.
Grant
Wise man once said, “Don’t fight fire with fire”.
Depends if you’re going after Euro racer look (56cm) or Lance the mountain lion (58cm). Either would work and it really depends on how you’re going to ride the bike. I can fit a 54, 56 or 58 w/o much trouble…
Here’s my 54 Soloist and 56 SystemSix (photo centered at BB). Hard to see the extra 2cm, eh? The challenge with any road bike is the front end set-up, not usually the top tube. There are a tons of issues b/w reach, drop, hoods, etc. This is compounded using Campy, Shimano or SRAM.
Generally speaking, I’d rather ride a 120 stem than a 100 stem…if that helps.
http://tinypic.com/2nrfrlc.jpg
I have a 54 P3C and a 54 Soloist. I went through the same decision process. Cervelo advised me to go with the same size in both, as did my LBS. The 56 would have fit fine, but I would have needed a shorter stem and the headtube was quite a bit taller. The 56 was a lot of bike for me (I’m 5 '11). I have been on a 56 and a 58 Trek OCLV prior to the Soloist. The Trek’s sizing is messed up as the top tube length is quite strange in the various sizes.
If you wanted a short headtube for the P3C then why would you go up a size for the road bike? The 54 P3C has a 10.5 ht, 54 Soloist 14 ht, and the 56 Soloist 16 ht.
The 56 will be a jump up in terms of position. I would advise you to go with the smaller bike (54).
I needed a shorter headtube for the drop i wanted and quite honestly i still want an adjustable stem to go lower. But thats beside the issue. The headtube wont matter as much on this one as i’m not trying to get aero on it. I could fit fine on a 56 if i wanted to the drop just wouldn’t be where i wanted it. Would the headtube really make that much of a difference on the road bike since im not trying to get aero on it?
Grant
It wasn’t a big fire… maybe just a couple matches :slight_smile:
Thanks for the pictures like i said in the previous post i can fit on a 56 p3c with no problems and possibly even a 51 if i wanted to. I just wanted to hear if there was any big sizing difference on the bikes between the two. and i acouple cm’s aren’t that hard to adjust for.
Grant
FWIW, i think you should go with the smaller size based on the info you gave. The main issue is not so much headtube length (though it can be) but top tube length + stem length. Most people more or less know what that “overall reach” equates to, and work from there. There might be small issues with which size offers a more preferred ST angle though that is usually mute in the mid-large sizes. So the question really is do you want a longer stem or a shorter stem? i am assuming here that the 2 cervelo sizes effectively mean a stem length difference of 2cm either way. This answer you have to come up with yourself since everyone has their own preferred stem length. I like my stems to be 90-105mm while someone else may never enjoy riding anything less than 140mm.
I guess it depends on what you want. I want to be as aero/fast as possible on both bikes and I didn’t want the positions to be too different. Why wouldn’t you want to be aero on your road bike? If you don’t care about aero, you don’t need the Soloist. The Soloist is the most aero bike in the pro peleton in terms of position and tube shapes.
I wanted to be able to move from my road bike to tri bike without it feeling too radical. The Soloist has a much more aggressive position than my Trek, at first I thought it was too low, but I like it now because it compliments my position on the P3. Going from the Trek to the P3 was a challenge, this is much better.
I also thought I could use the Soloist with clip ons for some uphill/hilly races. The larger frame would not be ideal for that.
I have both and both are different sizes.
My bikes are different sizes not because one is a triathlon bike and the other a road bike. They are different sizes because the geometry between the two is different. Actually, one of my bikes is labeled “48 cm” and actually measures 45.5cm.
What bike manufacturers label as “size” is different between brands and between bikes within brands. Some measure their frames C-C and some C-T. Also, what the generic charts say online is not always correct. Very often we get a bike in the shop that is suppose to have a 120 head tube and a 56 top tube and it measures 115 in the head tube and 54.5 in the top tube. (just an example)
My suggestion is to see a bike fitter near you and let them tell you what frame geometry is appropriate for you and what “size” you’ll need in your new bike.
Good luck and happy riding!
Better to spend a little extra and get the right bike in the right size than to purchase the wrong bike in the wrong size and spend hundreds trying to make it fit you. Just my 2 c.
The point was that a 2cm difference in a road bike isn’t as big of deal as a 2cm difference on a tri bike.
FWIW - I used to ride a 52cm P3C.
