Oh the doubters! “You are not pushing enough watts to break the frame”. I am a Clydesdale Sponsored athlete racing at 225 lbs , and in 2007 I rode the Guru Crono , 2008 the Cervelo P2C and 2009 the Cervelo P3C. I will tell you that as a larger rider pushing huge watts, you are generating tremendous torque that will destroy these carbon frames. The “Tour” riders do not generate the same torque as most of them weigh less than 160lbs.
When I first began researching Carbon bikes for a rider of my weight, I was given the same bullshit line of “you are not generating any more power then the riders on the tour, and they do not break these bikes”. I would dispute this claim as I generate more watts and much more torque. This is not a claim of riding faster than the guys on tour, although I do fly; watts to weight ratio ultimately determines our speed and although we are stronger, we have to push the extra weight around which is a huge detriment in cycling. Bottom line, I destroyed the Guru Crono and the P3C, plus 2 carbon cranks in the past 2 seasons.
The Guru Crono was a good bike as it was my first carbon frame. These bikes are not truly custom bikes as Guru would like you to believe and they are slugs in terms of aerodynamics. Their customer service is terrible and I would not recommend this bike or company for any larger rider. Guru promotes the beefier frames which I had, but I still broke the bottom bracket area of the frame. Guru did ultimately replace my broken frame under warranty, but the process took 8 weeks in the middle of a season forcing me to purchase a back up bike, the P2C.
I jumped to Cervelo as it gives you the biggest bang for the buck. For 2K, I got a proven Carbon frame on a truly tested model. I have been very happy on the P2C and would absolutely recommend it. I loved the P2C so much that I put my Replacement Guru Crono on Ebay and have never looked back. I was clearly faster and more confident on the Cervelo.
In 2009, I upgraded to the P3C and love the bike. It is more aggressive, more aerodynamic as well as being very stiff and fast. Caution though, you need to be a solid athlete in terms of body shape and flexability to ride this bike to its potential. I will tell you though, I broke my Cervelo P3C last week due to my power and torque and am currently waiting for Cervelo’s ultimate decision as to what they are going to do for me. I am now back on my P2C back up bike for the next few weeks.
As a larger rider, you need to accept the fact that you are crashing the party of the skinny kids!.. lol …Triathlon is not conducive to us in both level competition and equipment . I love this, as winning is that much sweeter in the end, but you have to give up something in the process. Understand that you will go through equipment faster than most to include, chains, chain rings, wheels, frames, areobars , cranks, ect ; this is all part of the deal…Go Hard or go Home. I can flex any of my carbon frames at will, as the Power and Torque ratios I put out are off the testing scales for these companies. On tough climbs, if I really get on it out of the saddle, I will rub the rear wheel on both the P2C and the P3C. This is also how I snapped 2 carbon crank arms. The trick is, you have to learn how to ride without promoting the torque or force that we can easily produce. There is a balance between speed, momentum and money. Something you will need to work out as a larger athlete. I would encourage you to go with Carbon tough, as it is the lightest, fastest, stiffest frame you can get. It also rides like a train on rails as compared to Aluminum or Titanium.
I would strongly suggest going with the Cervelo over the Crono . Cervelo offers tremendous value and a seriously fast bike. I will tell you though, depending upon how Cervelo responds to my latest problem, I would consider the Argon 18. If Sinballe can crank on this bike, my guess is it might hold up a bit better. After all, he is one of the larger pros (former unfortunately ) cranking out on carbon and he has had tremendous luck with this product. Unfortunately , Cervelo does not have any larger pro riders utilizing their products, at least not that I know of.
Good luck. Keep cranking it out. In the end, it is only money!
Clydesdale
