I got my new Cervelo P2C bike last Friday and the bike shop installs Ergomo Pro unit for me, but last night I rewire and relocated all the wires with 3M invisible tape. Check the picture and you will notices that I love details is hard to see the wires J
I don’t know if it is my machine…but I can’t see the pix.
can’t see em either…
Please hurry and FIX, i am sooooooooooo bored at work.
tfun~
right click → view image
I do not get that option when i right click?
tfun~
when i go to the pic links, it says FORBIDDEN!!!.
It looks very nice. I would change the location of the cable where it runs up the side of the downtube in the blue, to run it up in the black (like an inch closer to the bb from where you have it) and then the only part you’ll see from a distance is the black cable across the white stripe and blue frame. That’s just me though…and, no, I do not have mine that pretty. ![]()
Did you look at all into running the wires inside the downtube with the other cables? Rappstar did something like this with his SRM (I think it was SRM) but I don’t know how easy it is to cut and splice the ergomo cable.
Will the edges of the clear tape attract dirt and eventually become visible?
I see 'em, looks good.
Pictures are Fix now
I can seeeeeeeeeeeeeee, very nice job. Now i have to go re-do my bike shops work because you inspired me!
tfun~
looks good.
Am I missing something or is your stem negative rise? If it is, then flip it over and lose a spacer or two.
Nice bike, I like the P2C a lot.
I see the ERGO on the aero bars, i installed mine on the stem so i can still use a front drink system. Do you use a front drink system?
tfun~
Clean install. My notes:
Might want to consider using the spacers/shims to get the wires closer to 9pm on the BB install. I’ve found this is important.you could route the speed sensor wires under the BB shell and on the inside or bottom of the chainstay, to get them them out of the way. Mounting the sensor at the far rear of the stay is the way to go, to get rid of the slack.I routed my monitor cable on the bottom of my downtube (P3C) all the way up, jumped it over to the front brake cable and went up from there. Note that I have my bike set up moto, with the front back on the right, so this is a short cable for me that runs right to where I have the Ergomo mounted.
Below is a picture of a local customer’s improvised stem mount. I’ll configure mine like this.
tfun~
I thought I was the only one
does that ergomo computer have much of an effect in aerodynamics?
Rich - how is that custom stem install done? Do you have any tips on that?
