Cervelo bbright to shimano
Apologies if this has been done - I’m picking up a 2016 p2 tomorrow and one of many changes I plan to do is ditch the fsa gossamer crank that comes standard and install some ultegra cranks.
I have never worked with bbright before but is this all I need here : https://www.pushys.com.au/wheels-mfg-bbright-shim-adapter-for-shimano-24mm-spindle-cranks.html ?
Or are there better options instead of shims? I see wheels also make full bottom brackets but am unfamiliar with angular varieties etc.
thanks for any help
I have never worked with bbright before but is this all I need here : https://www.pushys.com.au/…-spindle-cranks.html ?
thanks for any help
They will work, but not optimally in my experience and certainly will not help if you develop a creak (not that uncommon). Here is another way to go and there are several like it the thread together and provide and can make up (to a degree) of some of the wide tolerances on some Bbright BB.
https://wheelsmfg.com/bottom-brackets/bbright/bbrighttm-outboard-abec-3-bb-for-24mm-shimano-cranks-black.html
There are now a couple of one piece designs out there as well, but I have not tried those.
I personally use locktite 641 on all BB that adds a little security for creaking.
Cheers!
I prefer BBInfinite for BBright conversions. Great product.
Awesome thanks guys - thought the shins might not be to flash
I had the cups for a while but then switched to https://wheelsmfg.com/bottom-brackets/bbright/bbright-out-angular-contact-bb-for-24mm-shimano-cranks-black.html
It’s been rock solid after about 3k miles. A word of warning - you need some tools to install it - like this one https://wheelsmfg.com/universal-bottom-bracket-press.html
Knocking the BBRight out of the shell is a bit of a hassle but can be done with a 2x4 or something like that. This tool makes it very easy - https://www.westernbikeworks.com/product/park-tool-bbt-303-bottom-bracket-tool-set-for-bb30
I have 3 bikes with 3 BB Infinite bottom brackets. Phenomenal product. And they’re local to my city so they install on my bike themselves. 😀
