Excellent condition 9s/10s FD, 31.8mm clamp-on. This FD is actually a 10s that I used as a 9s by removing the plastic insert. It can be converted back to 10s by purchasing a new insert at your LBS. (Actually works fine in 10s drivetrain without the insert, but snappier front shift with 10s if you use the insert).
John McGuire
Seattle, WA
