Carrying bikes and gear?
The last race of the year was one when we decided to camp. We put two bikes on top of the Outback and all of the camping and tri gear inside. The cargo space was piled to the ceiling, and the back seat was completely full (including the lap of the person sitting there). A tent and two sleeping bags went home with a friend. Clearly I need more space. Has anyone tried the new Yakima Skybox 12 (the next size up would be too wide to allow bikes). Looks like it would carry enough, but I’m not sure if it would interfere with the tailgate.
I have a Thule box on an outback and yes if you mount it in the holes provided it will interfere with the tailgate/hatchback.
Fortunately you can normally just drill new holes that are a bit farther back and thereby mount the box farther forward.
However there are older style Thule boxes that did not have a flat bottom, they in fact had a section that dipped down (I believe it was designed to allow the bindings on your downhill skiis to fit better). I found these boxes impossible to mount on an outback without allowing the tailgate to only open about half or two thirds of the way.
I don’t know if you can drill new holes in the Yakima boxes though and still have the mounting system work. The Thule ones have some molded channels in the bottom that restrict where you can drill the new holes but it works on an Outback.
I think my box is a Thule Frontier
http://www.thuleracks.com/thule/product.asp?dept_id=11&sku=668TT
I suspect the Thule boxes ar compatible with Yakima bars.
You might consider bringing your car to a place that sells boxes and see if they will let you rest it on top to see how the mounting will work.
That cargo box is about the size of the one I was looking at - would probably work OK. Were you still able to get two bikes on top - did they go inside the rails for the factor rack or did you need to get longer cross bars and mount them outside the factory rails?
Here is the kicker with all the roof-mounted boxes. Based on my previous salesman experience with these guys at REI, the one thing to remember are weight limits and liability. If you mount an aftermarket (Yakima/Thule) box on non-aftermarket (factory) crossbars, any damage to the roof is not the responsibility of the box manufacturer. Even using aftermarket bars to support the box still has a downside in that the bars have a set TOTAL weight limit. For most bars this is in the 130-200lb range but some are higher depending on the size of the bars and the make of the car. So you take two 20lb bikes, plus the 10lbs of rack to hold the bikes, plus a 40lb box and all of a sudden you really only have 40-50lbs of usable weight. Sure you can put more in there but it goes back to what the warranty would be and it won’t cover overloading like that. If you plan to use the box for light stuff like sleeping bags, small dogs and clothes you’ll probably be fine - but tents, cooking gear, etc. can increase your weight more than ‘filling’ the box so you have a tendency to put too much stuff in.
My two cents would be to look at what equipment you are bringing along and determine what all you really need to have since that sounds like a lot of gear for two people but I didn’t catch how many people you had packed for - guessing 3-4? which would make more sense.
Good luck, and definately go to an REI or rack-install place and see what the different boxes look like and how they fit on your particular car.
Josh
You put small dogs in a cargo box???
I used the standard size Thule cross bars (50" I think) attached to the factory racks. The factory bars (that run width wise) were removed.
I was able to mount two bikes using fork mounts, one front facing, one rear facing and one wheel holder, along with the Thule box.
The one bike rack and two of the four mount points for the box sit outside the factory rack but still on the standard Thule bars.
I suppose a picture would be easier to see but going from drivers side to passenger this is what you run into along one Thule bar:
  • End of thule cross bar
  • Frontward facing fork mount bike rack
  • Adapter to mount bar to factory rack (attaches to the permanetly mounted rack that runs lengthwise on the car)
  • Rearward facing fork mount bike rack
  • Wheel holder
  • Thule box clamp holding box to bar.
