Carbon-X bars and cable routing?
I am setting up a new pair of carbon-X bars. Can someone post a picture of how you set up your cable routing? Do I bring the brake cable through the lever and then out the first hole on the base bar, and then out the slits on the flat section and down to the calipers?? And then run the bar-end shifter cable along under the bars(bar wrap them to the bar??)…
Thanks,
HC
Thanks,
HC
Run the cable all the way from brake mounting hole through to slits on flat section. You might want to start at the slit end to make it easier.
Run the shifter cables through the bar and out the little slits on the bottom of the bar and out to the cable adjusters.
