Carbon wheel with metal brake track
HED Jets. I bought the 60’s last year and they are insanely good.
What say others about the HED Jets?I only have one Hed Jet wheel, a ‘6’ front (Stallion). I also wanted metal brake tracks because they simply work better and it’s easier when you’re training with aluminum rims.
My Hed Jet has been awesome, have it 4 years now and it’s been rock solid. Not even the slightest bit out of true, and it’s nice and stiff without being too harsh. My rear is a Flo 90, which is also OK, but I think if I ever buy a disc it will be a Hed. The stiffness is simply better than the Flo.
Can I ask how you are comparing the stiffness? You are claiming that our stiffness isn’t as good, but you are comparing a front wheel to a rear wheel. You also have a “stallion built” HED wheel and it appears a standard build FLO wheel. Also, know that wheel stiffness is often misunderstood. A very stiff wheel can actually cause the frame to flex more than a wheel that is not as stiff. This leads people to think the wheel in flexing when in reality, the frame is flexing. I’m not saying that HED does not make good wheels… they make great wheels. I’m simply saying it’s hard to compare a front wheel to a rear wheel and say, the FLOs are not as stiff. Especially if one is a stallion/clydesdale build and the other is a standard build.
Hed Jet 9 on the front, it is pure awesomeness.
If you were interested in a disc rear, I would have recommended a Renn 555 which is what I have. It is also awesomeness, and different to a lot of other metal brake track discs in that it is a solid carbon structure rather than a faring over spokes. So it goes WHOOOMP.
Another fast and strong option: previous generation zipp 808 clincher wheels. Lots of lightly used ones out there, and even some new ones.
http://image.ec21.com/image/bikeku/oimg_GC03020177_CA03020203/Zipp_808_Clincher_Wheelset_Carbon_Shimano_700C.jpg
If money isn’t a major issue just get the Jet+. Top notch design and quality. They are also about the only aluminum brake track wheel that is specifically designed to perform well in cross winds with the SCT profile.
Flo’s are nice and the best bang for the buck, but they don’t make a 40-50 mm rim and the 30 might be giving up too much aero performance.
Since you seem to be putting a premium on cross wind stability, the price difference between the other wheels and the Jets is probably too small to warrant being a cheapskate.
