Carbon Specialized (S Works) Crankset
S-works Carbon Crankset with new ceramic bearings - **$300 **
Purchased used (though no wear appearent on any item, it appears to be a take off of a SL2) to build up Transition Comp and found that I didn’t have an oversized BB…thus selling.
Any questions, feel free to shoot me an email justin_dyell@hotmail.com
Best strength-to-weight crank on the market 2nd generation hollow carbon crank arms offer superior stiffness Oversized alloy spindle with Hirth coupling interface Self adjusting oversized 42mm cartridge bearings Fits Specialized frames with oversized bottom bracket shell BB30 compatible Fast and smooth shifting S-Works chainrings, Standard 130mm with 53/39t chainrings Additional Standard and Compact compatible spiders and rings available separately Natural gloss carbon finish Weight with Standard rings - 635g (172.5mm crank including all hardware)
I will provide pictures upon request.
Bump
Just to verify, the cranks are 172.5mm correct? It is hard to be sure from the last bullet.
yes, 172.5 is correct.
